PCM reset...
PCM reset...
I am not sure if it needs to be reset, but yesterday I noticed that my Recent Calls list on the PCM had disappeared from the car, however it was still on the phone.
Shutting everything down and restarting it did not seem to make the list on the PCM return, so I am curious as to why this may have happened, or if I am doing something wrong - which is a possibility.
Any thoughts or suggestions are welcome.
Cheers,
Cheers,
Cheers,
Cheers,
This one is a 991.2 - and the only thing it isn't doing is updating the recent calls list, my contacts and everything else is working fine.
Should also mention that it is an Iphone that is having this issue; the Android works fine.
Cheers,
Cheers,
Thank you Sir - I did try powering it off, left it off for a few minutes and powered it back up. I will go into the settings and see what other kind of resetting I can do.
Cheers,
Cheers,
Vulcan Neck Pinch: hold the power switch and home button down simultaneously until it power cycles and you see the apple logo on the screen.
