Misfire Detected
It is becoming very apparent to me, that these cars do not like vacuum leaks and these leaks can cause other seemingly unrelated codes to appear.
You should be able to change the coils/plugs and then do a pressure test and listen for leaks - no leaks detected, put 'er back together and enjoy. I was thinking that it wasn't apart, this will make it much easier to check.
After Dealer says problem with coil pack. Full 60K service was done less than 3K miles ago with new plugs, but presumably didn't put in new coil packs (stupid. It was before I owned the car, dealer prepping it for CPO which it has).
Codes where:
P0301 (Cyl. 1 Misfire)
P2302 (Bar ignition module on cyl 1, soft shutdown).
(and a course a bunch of others, but I think these are the relevant ones)
Also waiting to hear if coil packs are "wear and tear items as defined by PCNA". Kind of sucks, the coil packs themselves are not that expensive, but dismantling the rear of the car for access, which THEY JUST DID for the 60K service, is quite a few book hours. There is no "scheduled maintenance" replacement for the coil packs.
After dealer pulled codes, they said they were going to reset them, but when I got back in the car the codes were still present. So either they reset the codes and they reoccured almost instantly or (my theory) they didn't actually reset them even though the service writer said they did. I
I reset them myself when I got home, and so far, at least on a short test drive, they have not reoccurred.
Sigh... This is why I do most work on my cars myself.
Has anyone ever seen an official list of "Wear and tear items defined by PCNA "? Sure, brakes, tires, wiper blades, clutches and spark plugs are obvious "wear and tear" items. I personally wouldn't consider coil packs to be "wear and tear", and they are not a "scheduled maintenance" item, and IMHO a coil pack failure under original or CPO warranty *should* be covered. Service manager wasn't in, so I won't hear more until Monday.
Codes where:
The hard part for me was the heat in San Antonio while working on it.
But I will be more than a little irritated if it is not covered under my CPO, especially since they just did a full/major service ~3K miles ago.
