Have you guys hit the overboost button to achieve 20 psi? I didn’t think that was active in sport plus mode. I’ve only ever seen 19psi regardless what I do.
Sport Plus already has Overboost. Normal and Sport does not and you have to hit the button. I set Individual up for normal Aero and OverBoost so it’s the beat of both worlds for Drag Racing. Max boost and least drag.
I'll have to start looking for 20 now. I've run 22-24psi and have only noticed 19....but at that speed.....I might miss it....
Have you seen 20psi ?
Only a few times, due to speed traveling. But I can hit 18 PSI in Normal mode without even trying due to the APR Tune. To get to 20 PSI place the car in Sport Plus, start out in a lower RPM and as you
accelerate try to keep within a certain torque range (2,250 and 4000 rpm) on the Torque-Hp graph when you are in overboost. Shift up to a higher gear if needed to stay in the band. It's a powerful car so be careful. And if that isn't enough, hit the Sport Response Button, try keeping in the range I gave you, and you should see 20 PSI.
