Cobb ots stage 2 tune
Anyone know if it’s safe to run a Cobb OTS stage 2 tune on a 991.1 turbo s with BMC drop in filter and quicksilver catless exhaust?
I know their stage 2 requires an aftermarket exhaust , just not sure if Using a test pipe would cause any lean conditions over a high flow cat.
I have 02 extenders already installed and no cel lights .
thanks
thanks
You should be GTG. I checked with my tuner and he told me I'm GTG on a stage 2.
I was running a Stage 2 with a catless 3" x pipe...now with cat bypass tubes and stock muffler setup.
I was told to run stage 2 (for the right gas of course), with SBR (standard boost response). I'm currently running stage 2, 100 octane with cat bypass tubes/stock muffler. No problem per my tuner.
How's the drone with that catless quicksilver?
MotoJB (02-14-2020)
I'll add that I didn't use 02 extenders as I'm going to tune out the CEL with COBB.
Can you also tune out the readiness check on the sensors to pass emission inspection? I’m using the extensors plus tune to be sure but haven’t had my inspection due yet.
On past projects I may have disconnected the fault circuit in order to avoid CELs, and even added additional wide-bands - the more data the car can use, the happier it will ultimately be.
