Car Reset
I've been through it on a 991.2... I'm not sure this deletes EVERYTHING, but it's what I've done in the past.
In the MFD, from the Vehicle Display (with your temps and whatever) hit the button/wheel on the steering wheel, scroll down to Settings, and the last item is Reset.
On the PCM, hit the physical "Car" button, touch the "Set" button, touch the "System" entry on the list, then you get another list that contains "Factory Settings".
On the homelink garage door buttons above the mirror, hold the I and III buttons at the same time for a long long time until it flashes.
