JackPoint Jack Stands
Old news, but the first time I have used them. Awesome tool !
on a side note, it took 600ftlbs of breaking force (me) to loosen a 442ftlb center nut. 36” breaker bar needed as a minimum!
Sounds about right - my torque wrench is 48" long and I have no problem moving the car/steering cracking that nut unless there is someone in the drivers holding the wheel and brakes.
BMS (01-29-2020)
Quick test today even though it was 43F outside and not really a summer tire testing temperature . The Pirelli N1's in 43F would 60ft from a best of 1.74 to a worst of 1.82 seconds. The Michelin 4S went a worst of 1.71 to a best of 1.65, a full 0.10 improvement in the 60ft in cold temps. Plus the Michelin's are brand new and need some seasoning . 0.10 improvement is massive. Hopefully that delta holds on a 70F day.
From my Dragy Logs, at 63F the Pirelli picks up grip and the 60ft drops to a 1.65 second pass. Hopefully. the Michelin will go 1.58ish.
