ES700 991 vs IMS850S RS3 Half Mile Races
These built motor RS3's are moving. An IMS850 with the Iroz hybrid turbo just did a 9.1 @ 153 in the 1/4 mile a couple days ago. My buddy Erik did a similar Iroz Motorsports build and we got to hang out and do some fun runs at the most recent California Airstrip event hosted by Omega Motorsports in early November. Enjoy.
The Audi must have an enormous turbo in it; on the third run he looked like he was gaining on you. Your car, off the line in the first race, Audi didn't have a chance. Very impressive, thanks for sharing.
The 911 still has a huge advantage on a dig run. Rear engine vs front. I had Erik drop tire pressure a little but he wanted to be near 30psi both front and rear tires and I was 24 rear and 26 front. So further advantage to me on the dig. And even though his gearbox is built to handle the power increase, it can't shift as quick as the pdk so the RS3 looses ground on each shift.
Yes thanks was fun runs and a great matchup. These RS3's are single turbo and when built, they can handle the larger turbos but you see the result with lag on the roll hit. Before the second roll race I asked him to floor it well before the cones so that he's full boost at the cones but didnt work out. I would have liked a closer race as these cars match up nicely. Erik was cooling down between runs and I was hot lapping so by the second roll race I was likely down a bit on power and why he started gaining at the end on that run.
any other suggestions to set up the car for this? setting electronics...
again, thanks for your video's, always fun to watch!
Originally Posted by Elliott991TS
would you suggest running 24 rear and 26 front for optimal 0-60 runs?
I'm sure a drag alignment could help also. I've never changed my alignment. Same as came from the factory.
What mods do you have and what are you trying to achieve?
Thx. I've never done a dedicated 0-60mph only setup, but if I did, I would want the largest tire contact patch possible which is achieved with the lowest rear tire pressure to get the tire to "wrinkle". On a drag radial that would be around 14-15psi. On a street tire maybe 20psi. I ran a bit higher pressures because I was doing half mile dig runs so I sacrificed a little top end speed (higher pressures will yield higher trap speeds) with launch optimization.
I have a 991.2 Cab with Kline inconel headers and exhaust with 200 cell cats, no tune. Car is plenty fast for the street.
it makes sense to lower rear tire pressures for more rubber contact with the street, 20 in the rear is pretty low, I bet it makes a big difference
looks like you are having a lot of fun with those half mile races
For daily driving I actually run the stock OEM tune and run tire pressures at 30 front and rear. 30 seems to be the perfect balance of grip and comfort while keeping the TPMS light from coming on. Running 40 rear can result in wheel spin on launches.
Originally Posted by mikerosi
Hey Adam nice runs for sure
on your 30 front and rear tire pressure are you setting that at 65° cold
Curious thanks
Curious thanks
