how to access the engine?
Ok, here is my seriously noobie question....
how exactly do you access the engine to see the intake, or the plugs, or whatever?
removing the bumper cant be the only to access it, I mean i can access the oil and fluids when i pull the lever inside.... but that is covered with plastic piece .... so i cant even see the engine
help
thanks
help
thanks
To actually "see" the engine, removing rear bumper or access from below are the only options I believe.
On the other hand, Oil change is simple procedure by removing the right fan, to access the oil filter.
Former Vendor
help
thanks
help
thanks
help
thanks
help
thanks
Removing the bump isn't hard once you do it once or twice but it is annoying.
I have a "new toy" that I need to install. It is suppose to be super easy... but it involves plugging into the MAP sensors
So of course, I need access to that.... and maybe access to the firewall to route a cable inside
Any help would be great
I would use either or these instruction pdfs to reach the manifold pressure sensor. These are tutorials to install a y-pipe and/or plenum:
https://www.do88.se/bilder/artiklar/pdf/TR-210-991.pdf
https://www.do88.se/bilder/artiklar/...00SV-OEM-1.pdf
Ofcourse, only apply the steps you need.
Former Vendor
That's what's taking me so long to finish up the guide.
Emailed you back. Almost done!
