Full throttle acceleration question
So is there a difference once the car is under full acceleration what mode you are in? If I go out for some spirited driving are usually leave the car in sport mode. If I were to put it in sport plus is there any difference other than the fact it will hang onto the gears longer? Does it change boost or do anything else?
Former Vendor
I believe it's only for the PDK system and trans line pressure.
So the car is definitely quicker in sport or sport+ mode. Over and above Sport mode, Sport+ also changes the PDK programming and raises the rear spoiler and lowers the front air dam.
But from a boost perspective, sport and sport+ are the same.
Leaving the car in regular mode results in less mid-rpm boost, resulting in max torque of 516 lb-ft. Putting it into either sport or sport+ gets you over-boost (and a louder exhaust) for a limited time (20 seconds) which increases max torque to 553 lb-ft. You can see this when you select the power graph.
Sport+ holds in lower gears for longer than sport, when not at full throttle. And sport holds in lower gears for longer than regular, when not at full throttle.
Former Vendor
What about sport chrono mode, when will that be applied?
Here is what I know. If you leave the car in regular mode, the Porsche spec page says you will see 516 lb-ft of torque from 2100-4250 RPM, whereupon torque will start to drop off. Max hp is 580 at 6750 RPM.
You can back-calculate torque at max HP RPM: 580 HP @ 6,750 RPM suggests the car is making 450 lb-ft @ 6750 RPM.
In some of the various perf 'modes' or settings, the car will provide 2.2psi more boost, adding 37 lb-ft of torque, but only in the RPM midrange. I haven't found anything which is conclusive about the RPM band in which this extra torque is available but likely it's the same range - 2000 to 4500ish RPM.
Now why wouldn't you be able to see this in a data log? Here is my guess. You start your data log and run your car through the gears. But if you look at the RPM shift points, when the transmission upshifts at 7000 rpm, it is probably hits the next gear at or above 4500rpm. So during timed acceleration runs, you may not benefit from the extra mid-range torque because your engine is always revving higher than the point at which that torque is available.
If you wanted to test just the over-boost, I would suggest the following test. Do two runs, one with it and one without it. But in each run, start the test at 2000 rpm in 3rd gear and go full throttle from 2000 RPM to 7000 RPM. Just third gear. This will spend some time in the rpm range where over-boost happens. Let us know what you find!
Interesting that your data logs don't show anything.
Former Vendor
I'll find the files tomorrow and load them up. If it wasn't raining I'd go out and get more logs for you
PS, I'm one of the product developers at BMS. I do tech support as well and dial in the JB4 system for customers. I evaluate logs for hundreds of our customers around the world in many various platforms that we offer tuning services for.
I really like what you said about the data and the runs, that's very very important. It needs to be consistent, or else the data is useless
What you stated is EXACTLY what I ask of our customers when comparing data logs from stock to tuned etc. These are my usual posts after reviewing some logs:
https://www.n54tech.com/forums/showp...23&postcount=2
also, how many 20 second intervals do you get on the track, for example, if left in sport+? How quickly does the 20 second timer reset?
But I think the 20 second business is somewhat of a red herring. I don't actually know if that applies to anything more than pushing the button on the steering wheel which gets the car into the lowest gear possible and holds it there for 20 seconds.
And honestly, that button seems like a total gimmick. Why would you ever push it except for just screwing around? All the car's performance is available in sport and sport+ modes without timers or buttons, etc.
