991.2 intake blew up before throttle body
Is it just the plastic accordion piece that broke or the aluminum manifold itself. If is the former I would say just replace the coupling or the unit with something more robust like the D088 silicone hose. Although this should not happen, plastic can develop cracks from age and exposure to certain chemicals.
Looks like a factory defect, see if the dealer will warranty it.
Originally Posted by pepinozaur
Thanks guys, I decided to order the stock part again and give it a second chance before moving aftermarket. I am not really that much into seeing benefits from bigger ypipe and TB anyway, at least at my power level
If others are running stage3+ and not having problems, then I should be safe.. thanks!
Former Vendor
I just did 144 quarter mile and 175 half mile on a 88 degree day nearly 4,000 feet DA through the stock Y pipe so I don't think the stock Y is hindering performance on a stage 2/3 car. The inlets look like they could be a restriction however I did a 144 quarter mile and 174 half mile on a completely stock intake system (stock inlets stock Y and stock plenum).
