Oil Leak
Oil Leak
I noticed a small amount of oil on the garage floor this morning, under the passenger’s side engine bay. The large soft hose there has a slight film of oil on it. Checked my oil level and fine. It’s a 2017 TT with 17,000 miles. I’m due for an oil change and the dealer is an hour an half away. Work takes me there in 2 weeks, any thoughts on if it’s safe to wait? Just keep checking the oil level and if ok and slight leak, wait? Any thoughts on source from this area if a known issue? Thanks and this board is a great source of information and helped me confirm the TT was the right car.
Since it only dripped a small amount, the oil level gauge will not show low oil levels. If there's a small leak, it may take days to show that. Regardless, I would follow radar979's advice.
Do you mean these rubber hoses? If so, you probably need to replace them. The problem is a missing rubber seal that for some reason goes missing
I tried searching to see is they sold the seal by itself but was unsuccessful. It is a simple diy but requires taking off the wheel and liner to do so. If you need instructions to swap it out, I can help.
Did the dealer take a look at it?
Mine was leaking because the pipe was missing a rubber seal from the intercooler side. Not sure if it was in fact oil or soemthing else, and where it was coming from (turbo or intercooler).
Just got the car back from the dealer and the diagnosis was oil leaking from porous turbo boost hose on passenger side, hose was removed and replaced. My service advisor said this was most likely caused from physical damage from the road but covered it under warranty. I’m no engineer but it seems like a rubber hose shouldn’t have that type of exposure. I meant to ask how much replacing the pressure hose would have been without warranty but forgot. By the way a new key, programmed was $513, steep I think even for a Porsche. I will say my service advisors were excellent in all aspects. Thanks for the inquires, this is an excellent forum with great contributors.
FetalEcho (10-08-2023)
This is how mine looked on the intercooler side before I changed it.
Some turbos will have oil migrate through the CHRA. Winds up in the air track. I’ve cleaned out Intercoolers with oil in them. Too much, and an internal chra seal is toast or the pump is toast. Generally the exhaust smokes if the pump is toast. Having an oil film in that pipe isn’t too concerning.....the pipe leaking is. Leaking oil = leaking boost.
