991.2 Turbo S 1/2 Mile - Stock MPH?
Basic Sponsor
Sorry I could have sworn I typed .2
Yes I would say 158-160. Like a stage 2 991.1 (which can barely edge out the 160). A stage 3 991.1 can run about 163-165 and stage 4 167-184 depending on how aggressive everything is set up.
Proud TOP Porsche Distributor For:
Kline-Innovation - ams Performance - TiALSPORT/XONA - #1 COBB PRO TUNER - CSF - IPD Plenums - DO88 - dodsonmotorsport
310-600-1850 - sam@bydesignauto.com
Thank-you for your response...this is what I have also heard - about equal to a 991.1 stage 2. I will let everyone know what I run...
Thank-you for the feedback...I have been debating the launch simply because with poor 60' in the 1/4 you tend to MPH higher (and lower MPH when you hook). I have found in my 1/2 mile racing that the second 1/4 is key - but being fair I haven't had the traction capability of the Turbo S (I ran a modded C7Z and also went 178 MPH lol). I simply ran through the gears - speed shifting versus power shifting - compared to trying to launch it - this gave me my best MPH - but being fair - not by much (2 MPH). My launch as you can see isn't fantastic. I will try both methods with the Turbo S and report back which worked best...
https://www.youtube.com/watch?v=LWobj36qSr4
difference that would have made but would have definitely like to see each method.
That was 760 wheel and perfect traction, car ran the same thing over the course of the 2 days , 0-60 in 2.5, 1/4 in 9.75, it ended up doing the same thing to the last digit twice between saturday and sunday. I dont think anything else is capable of that consistency and thats what makes trying different stuff so easy.
https://www.youtube.com/watch?v=j41A...annel=arkadyzv
You can see how it starts to lose steam up top
How much power was the c7z making? Its funny because I'm currently doing a Procharger F1A94 on my 17ctsv , so exact opposite lol, traction and consistency out the window but top end will be very nice.
Yeah how well the turbo's launches on unprepped pavement definitely put it into a different category vs something rwd as its very efficient for the power level. Definitely do an event, times aside the fact you are able to take out your car and go wide open throttle for a half mile without having to worry about a ticket is worth the price of admission alone.
Yeah theres definitely no set in stone procedure, IMO with the C7z you have real top end so while the launch isnt great it has the power to make it up on the back end and thats its strong suit vs the 911 the launch is the strong suit. But on the top end especially the shift from 4th to 5th it feels like it slows down a decent amount both with the gearing and also it being all out of turbo. Prior to going 178 in dallas, I went to the ocala event and it only did 173 or so, same thing trying to launch it but the surface was much worse and the car spinning really bad thus distance was just wasted. I never tried to just roll out and see what
You lose a bit of the bottom end responsiveness with the 94 - but it will pull more power up top. I wanted a more all rounder and stuck with the regular F1A. I have since added port injection, heads, forged rods and pistons, forged RPM trans, and a few other things for this season - but I won't be testing it - as it is going now that I am getting the Turbo S (GTR is going as well). I am pretty sure with just the additional fuel alone I would have went 180 - and with everything - probably lowish 180's.
I will try all combos - but I see your point - if power is low-mid range - I need all of it for the first half to back half the best MPH I can.
I look forward to finding out.
Try this for some IC data.....
http://www.evoms.com/product_p/8112.htm
Just noticed my link did not post .
So - a few questions. Will the IC's have this much affect on a stock 991.2? Looking at this - it seems it's with a tuned car? I find it both hard to believe and concerning that a balmy day still causes timing retardation due to the fact the stock IC's are apparently horribly inadequate?
I read a ton of posts about the IC’s being a problem with heatsoak. Typically near the end of the 1/4. That’s why mph is all over the board on stock 991.2’s. 128 to 131 is reasonable.
Dropping boost at 1000ft depending on cool down is an issue. Onwards to the 1/2 mile is a bigger issue. Rough numbers out are around a 4psi drop at 50c IAT. Really depends on ambient and cool down.
The vbox post, to me, is real data, but as you noted extreme outlier DA that I will never experience. But it is a data point.
Basic Sponsor
It all depends on what your goals are. There are many ways to do it so just depends what will be the best and most reliable way to get from A-B with longevity.
Modding is not for the weak. It has its benefits and its challenges.
That said - As someone who mods - it's always challenging to stay (at least fully) stock lol.
I agree. I have been in the modding game a long time. My current cars are in the 900 and 1600+ whp range. At the moment - I am looking to keep this car - when I get it - stock. I don't want to remove my ECU to tune and I'm hoping yourself and ESMotors and all the brilliant Porsche Tuners will figure out how to crack the ECU so OBD direct port access is possible.
As as far as modding goes agreed completely but this is the one platform where you can have your cake and eat it too without any drawbacks , loss of drive ability ect .
Which half mile event do you think you'll be attending?
Other than the launch , you will get bored with it quick lol especially since you are used to more . They are too smooth and drama-less from a pure feel perspective. Top end pull starts to feel like something once it traps at least 140. I can definitely see the IATs going high on a half mile pull with stock ICs although either iceing them down and having better octane will definitely help combat that.
I will be going to Battlecreek Speedfest in Michigan. July 5-6. I have been to many 1/2 mile events - and this one is the best (well run and perhaps even more importantly - the best runway I have run on - super smooth, 7000 or 7500 ft - I forget - but no issues at all for shut down, no dust or debris). Shut down isn't great - but I have been on many a airstrip that their main runway was like Speedfests shutdown.
http://www.bcspeedfest.com/
