Snow Tires
Old Nov 2, 2018 | 08:47 AM
Dennis C's Avatar
Dennis C
Rocky Mountain High
I’ll add a few comments: Sometimes older winter tires perform poorly, even though they have decent looking tread. The rubber compound can get stiff with age and become less pliable, rendering the tires ineffective in cold weather. I don’t know how to tell when a winter tire has gone past the useful life, other than how they feel and perform. I typically use mine for three seasons and then replace them. I’m not saying that your tires need to be replaced, but you should consider it if you install them and the car doesn’t seem to perform well.
Old Nov 2, 2018 | 10:01 PM
sdg1871's Avatar
sdg1871
Originally Posted by Dennis C
I run Michelin Alpin PA4 winter tires on the OE wheels on my 991.1 TTS. I bought a new set of custom wheels for my summer tires. This option has worked very well for me.
Same set up here. The Pilot Alpin 4s Work very well
Old Nov 3, 2018 | 03:47 AM
SilveRT8's Avatar
SilveRT8
X2
Pilot Alpin PA4 in 245-35-20 / 295-30-20 on stock wheels
Old Nov 3, 2018 | 02:18 PM
MaxLTV's Avatar
MaxLTV
Originally Posted by AKSteve
Anyone know if there's much difference between the N0 and N1 versions of Michelin Alpin PA4's? I've been running the same set of N0's on my Turbo for the past 3+ winters and I'm debating whether to upgrade or just keep these for another winter.
Nearly the same - not enough of a difference to throw away tires that have tread. Also, Michelin has Pilot Aplin 5 now, which is supposed to be a bigger step forward, but it's not available in Porsche sizes this season. So I'd use the tires you have for another winter (assuming good tread) and replace with the new Pilot Alpin 5 next winter.
Old Nov 5, 2018 | 04:50 AM
AKSteve's Avatar
AKSteve
Thanks for the heads up on the PA 5's. Looks like they have them in Porsche sizes in Canada: https://www.michelin.ca/CA/en/tires/...t-alpin-5.html
I wonder if these will become available later this winter in the USA. Or if I could possibly order a set now from Canada.
