Snow Tires - Rennlist - Porsche Discussion Forums
991 Turbo Turbo and Turbo S
Snow Tires
Old 10-29-2018, 06:58 PM
korntera
User
korntera's Avatar
Default Snow Tires
I called discount tire today and they said they had nothing available for standard sizes and they only had one option available for a "similar size" tire that would work.
He then brought up going with new wheels and tires and said, thank god you don't have the race nut... "Sir I said it only had one large lug on the wheel" Him "The 453 ft lbs of torque one?"
Yup, not sure how to get new wheels for this car, yet i also see many with 5 lug wheels in a 5X130 if im not mistaken pattern. How would i convert to 5 lug and is that tough to go back and forth?
I live in the PNW and make trips over the mountain and honestly think my Turbo S would do better in the snow than my Raptor. Its actually not very good in the wet and all snow tires look dumb on it because they have no massive mud *****. Wifes X5M runs snow tires but i can't take hers if she needs it for the day.
korntera is offline
Old 10-30-2018, 01:51 AM
neil.schneider
User
neil.schneider's Avatar
I believe that it is possible to change, but kind of expensive. I don’t know if it will be worth it why not consider just changing them back-and-forth twice a year?
neil.schneider is offline
Old 10-30-2018, 02:00 AM
korntera
User
korntera's Avatar
there is only one brand of snow tire available and they are $2,600 installed. Nobody makes the TTS sizes. Thought maybe someone would know of a less expensive alternative as my wife’s M has larger tires and they were only $1800.
korntera is offline
Old 10-30-2018, 03:47 AM
worf928
worf928's Avatar
Tirerack has wheel/snow tire packages available for center lock wheels. Only O.Z. wheels and Michelin snow tires but those are fine.
Porsche also offers a winter package: https://www.suncoastparts.com/produc...1G2STCLWS.html
worf928 is online now
Old 10-30-2018, 04:22 AM
MaxLTV
MaxLTV's Avatar
The standard winter sizes for Turbo and Turbo S are 245/35-20 front and 295/30-20 rear. Maybe there are options in 19", but that would be a gamble as to wheel fit. There are at least two good brands widely available in these sizes - Michelin Pilot Alpin 4 and Pirelli Winter Sottozero II, and a set runs about $1500-1600 on Tirerack or maybe even cheaper at discount tire places. Those are top-tier tires, magical traction on snow and ice, and some say Michelin is slightly better. These tires fit on standard OEM wheels, so you can just swap tires back and forth. If buying wheels, the cheapest option is to buy a set of OEM take-offs for winter. Often those can be found for way less than a set of any good new wheels anywhere, and they are very high quality.
So winter wheels/tires are not an issue, regardless of the number of nuts.
MaxLTV is offline
Old 10-30-2018, 08:54 AM
Dennis C
Rocky Mountain High
Dennis C's Avatar
I run Michelin Alpin PA4 winter tires on the OE wheels on my 991.1 TTS. I bought a new set of custom wheels for my summer tires. This option has worked very well for me.
Dennis C is offline
Old 10-30-2018, 04:01 PM
mwlmd
mwlmd's Avatar
I just went through the same exercise in my mind for this upcoming winter. I decided to not get winter tires and drive my Denali when its inclement weather. We will see how it goes. You might consider getting a set of severe snow rated AT tires for your Raptor. There are 3 options at tirerack. Dynapro AT-M, Goodyear Duratrac and Pirelli Scorpion.
Then save the 911 for those dry winter days!
mwlmd is offline
Old 10-30-2018, 04:08 PM
korntera
User
korntera's Avatar
I have goodyear Duratrac on my raptor. When it was 50 and rain it would spin the rear tires with anything beyond normal driving, not even full throttle so im scared that it will be awful. Granted that was in 2wd mode but my old truck with dedicated snow tires could ddrive in the snow in 2wd without any issues, 4WD was just a plus.
korntera is offline
Old 10-30-2018, 04:32 PM
mwlmd
mwlmd's Avatar
I hear you. My Previous Toyota Sequoia (2015) with Nitto Terra Grapplers would spin in 2wd mode on wet pavement every stop!! However in 4wd it was a beast and made countless trips to Hood and Bachelor and Montana in all types of ice and snow. Your Raptor will do fantastic in 4wd. I wouldn't worry one bit!
Plus we need to avoid all the winter gravel our lovely DOT dumps on the roads to bang up our 911s!!
mwlmd is offline
Old 10-30-2018, 05:37 PM
Dennis C
Rocky Mountain High
Dennis C's Avatar
It’s always nice to have a truck to drive in winter conditions. I’ve got a Denali 1500 Crew Cab that I drive in snow and slush. For me, the winter tires on the 911 are more useful for cold, dry pavement or for those unexpected icy patches in shady spots on the road.
Dennis C is offline
Old 10-30-2018, 06:27 PM
AviBen
AviBen's Avatar
I decided to go with the Porsche winter wheel set (currently comes with the Michelins, which I wanted). Went through my dealer, made a fair deal. They switch the wheels out twice a year, and store the benched off-season set, for a reasonable price.
AviBen is offline
Old 10-30-2018, 11:16 PM
neil.schneider
User
I just went through this same dilemma. What I ended up doing is buying a set of wheels/tires off one of the other rennlisters here. I am excited to drive my 911 through the winter without worrying about grip. Must remember that even if there is no snow or rain when the temperature falls below 40° the tires can easily slip. They become very hard. I’ve noticed this especially when going around corners.
Old 10-31-2018, 08:41 PM
Top Jimmy
Top Jimmy's Avatar
Need some weight in the back, otherwise the torque will spin tires out on a truck. They are just too light back there. Otherwise run in 4WD and have the weight of the engine over the front tires for better traction. Most folks here will throw some 50lb sand bags in the back between the wheel wells in the winter for more weight to stay in 2WD.
-TJ
Top Jimmy is offline
Old 11-02-2018, 12:25 AM
AKSteve
User
Anyone know if there's much difference between the N0 and N1 versions of Michelin Alpin PA4's? I've been running the same set of N0's on my Turbo for the past 3+ winters and I'm debating whether to upgrade or just keep these for another winter.
AKSteve is offline
Old 11-02-2018, 12:43 AM
mwlmd
mwlmd's Avatar
I would say if the tread is usable then use them. Winter tires have a limited service life so go by the remaining tread and not by the letters on the sidewall.
mwlmd is offline
Contact Us About Us Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
