Sponsored by: Road Spy
Replace battery on a 14 TTS as preventative maintenance?
Old 10-14-2018 | 06:20 PM
lowpue's Avatar
lowpue
Originally Posted by worf928
Two different issues:
1) loss of battery-backed ECU memory: curable with thoughtful use of a tender
2) coding of battery characteristics into (one of the) control unit(s). This requires the PIWIS laptop.
For #2 the speculation is that the amp-hour spec is needed for start/stop. If you use a battery with a different capacity you’re supposed to ‘tell’ the car about this.
Ah...thank you for that clarification....
Quick Reply: Replace battery on a 14 TTS as preventative maintenance?
