2015 with replaced rear fender stone guard film already
Previous owner replaced oem stoneguard film on rear fenders due to yellowing. Anybody else seen this happen? Seems kind of quick for a lower mile 2015. It is a white car.
The original stone guards are terrible. And not large enough to protect the car. I had mine removed on my TTS and had that area PPF’d up higher and from the door to the wheel well when I did the other areas. Much better protection and does not yellow
White cars with guards require replacement quite often - I do mine every 3 years on my white cab....tough to keep them clean on the edges as they show everything versus other colors.....I use a q-tip along the edge with every wash to keep them looking fresh...........I also use rubbing alcohol sparingly on the q-tip when dirt is stubborn.......
