I think 295 is the only width you can get for 20's when it comes to snow tires. You want snow shoes to be a bit more narrow anyway. I am a big fan of the Michelin's. I only got stuck once and that was because I high centered the car in deep heavy packed snow, aka my fault. Otherwise you are good to go until you run out of ground clearance, which tends to be sooner then you think.
