Handling / steering on 991.2 TTS and other observations
Hi folks, was chatting with Sam about some handling and steering differences I noticed between the .2 and .1. Wanted to see if anyone else can chime in. Sam said he has another client who had complained about same things so hoping to correct somehow.
Here’s the best way I can describe it. The car does not feel as planted or heavy as the .1. Steering is much lighter and no, I don’t have power steering plus. The steering wheel seems to jar left and right on banking and highway on/off ramps. Last night entering a highway I was on the ramp not going particularly fast, say 50 mph, and I felt the wheel jerk back and forth. Never had that type issue with the .1 which I could drive with my pinky. Steering wheel was just tight as can be and almost drive itself. The .2 seems to wander a bit. I also feel like the rear end feel lighter and unplanted. This happens with PDCC button on or off. Sport or comfort. I didn’t. Price much difference between steering firmness in sport either maybe a tad. On a positive note, it does uneven roads and bumps quite a bit more smoothly and softer. Although I had put the new N1 p-zero’s on my .1, the .2 seems to offer more road feedback. Smooth still but gravel feel is more prevelant.
If it weren’t for Sam confirming at least one other person who had both models feel the same, I’d chalk it up to my neurotic like brain. I am not disappointed but would like to have tighter steering as I had before. It may be characteristic of the .2 or maybe there’s a software issue. Who knows but will ask dealer to take a peek. When I drive the same car at PEC in July, at much higher speeds and turns, I did not at all feel like this is the same car. As I say, I’m not complaining, love the car, but I am so attuned to my cars I pick up every little thing.
Someone in another thread confirmed the sport seats changed. I realized that last night. The back bolsters, to me, feel tighter even on their widest setting and I recently lost quite a bit of weight. Not at all uncomfortable. I like them but did notice that.
PCM- I like the screen and graphics. I find that when connected via USB to either car play or just as IPOD, it takes a couple seconds to skip to next song on a playlist. In addition it seems I have to wait another 2-3 seconds for it to cache before I can then skip again. Burmester, especially with Musicar’s tweeter upgrade really is quite nice. I’d like to find a way to default the pcm to the iPod like it does CarPlay when I plug my iPhone in. Have to hit source or media a few times to get to it each time. I may try a USB stick or Sd card to see if any different.
PSM/PASM - where are the settings or is it just disabling traction control?
I'm going to leave most of this alone, but I find the .2 has slightly better steering feel than the .1, and I don't have any of the steering jitters that you are describing. The rear is just as planted in curbing. The biggest difference I notice in the feel is that this car will let you be a little more aggressive before it steps in, is a bit faster (top speed at VIR back stretch was 164mph in .1, 167mph in .2) It overall seems more refined in aggressive situations. You might want to check your tires or tire pressures again. The dealers fill them to crazy high pressures, and they should always be run at summer comfort settings. I suggest 33Front/36 rear for street use.
Hi, Never drove a .1 but my .2 TTS fells solid and planted on the street or track, similar to RandyC's comment. I also run 33/38 on the street and the steering is tight and never wanders.
So far, I did 4 hard track days, starting at 30/30 cold and about 35/36 hot, car handles great.
Something other than tire pressure needs to be checked on yours, possibly alignement ?
That’s right where my pressures are set. Even though Dealer initially forgot to adjust pressure from transport mode, car kind of feels the same. Wandering and and a light feel. I’ll gave to have dealer take a closer look.
Received 1,665 Likes
Part-load comfort pressure is 31/36 and is the same for .1 and .2.
I would have the alignment checked by a competent shop. Don't assume the dealer has an alignment machine. Unless they are a big multi-mark service location they probably sub-out alignment to a nearby tire shop.
Just checked. 31/36 is what I have been running. Exactly. Alignment was checked last week and is spot on. I have a message in to my techs and will see what their thoughts are. Regarding the “planted” feeling, maybe I didn’t use the right term but with the steering wheel jarring back and forth at times, that was my best reference. I’ll take it out this morning and see if I can focus a little better as to what’s occurring if anything.
Do you have 'Lane keep assist' (or something similar in name)!? I picked up a Macan with this option and it startled me as the steering literally will try to keep you in the lane?? I turn it off as it is a bit too aggressive for me taste! Probably not your issue but thought I would post!
Now my wife's AMG.. it will start by vibrating the wheel and then it will actually turn the wheel and even apply braking if it senses you are veering off the road. Happy my Porsche doesn't do this!!
Got it! Lane change assist is not the same! I too had LCA on my Turbo with the lights in the mirror area! Lane Departure is different (and in addition to LCA) for sure as the Macan is my first vehicle with it and it definitely 'grabs' the wheel so to speak if it thinks you are leaving your lane with no signal!
