Track Day with Small Leak in Tire?
So my driver side rear Cup2 tire has a slow leak - about 1-2 psi per day and settles around 24psi. There is nothing in the tire like a nail or other piece of metal causing the leak. It's just leaking slowly.
So....I'm going to a track day at Auto Club Speedway this weekend which is a pretty high speed track. The configuration uses half of the "Roval" (think Nascar) where a GT3 can sustain 150 mph. Am I being naïve for thinking about doing a track day at ACS with such a leak?
Thx.
Thx.
Have you checked your wheel for any damaged, maybe you have a small bend ? Personally I would rather be more on the cautious side when it comes to tracking, why not replace the tire? Good luck and have fun this weekend
Larry Cable (04-20-2022)
I didn't even think about the wheel. Great point. I just contacted GMG to see if they can get me in tomorrow to check it out. Fingers crossed.
I would never go on the track like that, but that's just me.
The following 3 users liked this post by Archimedes:
The following 3 users liked this post by Buteo:
Not on a bet.
abiazis (04-19-2022)
DO NOT DO IT.
I run frequently at ACS, including with Speed Ventures. (I'm not going this weekend, though. Too darned hot!) In my GT3, similar to yours, I'm going into turn 1 at ~150 mph. If you're losing air - and don't have a nail - it might well be a slightly damaged rim or tire bead. Either could cause a sudden and dramatic problem under the g-forces on the banking. I've also had the same "slow leak" problem. With me, it was a slight break in the bead of a brand new PSC2. Installation error? Defective tire? Can't be sure, but the result was the same.
The Fontana track causes more stress on a car that any other track in the SoCal area. DO NOT go out there if you have ANY questions about the condition of your car.
And I say that as a person who may share the same track with you.
You have a problem with either the tire bead or the rim. Don't track it until you fix it.
DMoore
'15 GT3
DMoore
'15 GT3
The following 2 users liked this post by DMoore:
abiazis (04-19-2022),
Another quick check to try is the valve stem- at the wheel and also the valve core. soapy water or even spit and watch for bubbles. Have had a loose/ leaking core a few times.
Yep, and if it's not the valve then dunk the whole wheel/tire assembly in water (they have this facility at tire shops) and see where the bubbles are coming from...
DO NOT DO IT.
DMoore
'15 GT3
DMoore
'15 GT3
Thanks guys. Don't know why I was being so stupid.
Confirmed an apt at GMG tomorrow morning to diagnose and hopefully fix. If it can't be remedied I'll take my other track car.
It really depends on your driving style. If you push the car hard and near to the limits, I would highly advise against it.
If you're just there to have fun much more so than you can on the street I would bet money that you would come out just fine.
I would probably bet money you are right, too. But i wouldn't bet my life. And that is the wager being made here.
PatrickBateman (04-19-2022)
DMoore
'15 GT3
