GT3 resurection
#33
Depending on the weather I take a hot or a cold beverage, lean on the pitwall and enjoy the race and track cars that roar by.
I always feel like a ***** for skipping the last session, good to know I'm not the only one :-)
#34
The potentially dangerous cocktail of increased confidence matched with increased tiredness is a good reason why sitting out the last session on track days makes so much sense
#35
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,371 Likes
Sitting out the last session comes down to the driver.
Fatigue, dehydration, and sleep deprivation effects are often worse than we realize. Caffeine can help, and naps are even better. Regarding hydration, if you're not peeing every hour or two, you're probably not hydrating well enough.
When I evaluated safety incident data, I did find that there tended to be more incidents towards the beginning and end of events.
The incidents towards the beginning of events were more commonly advanced drivers and instructors, with overconfidence likely being a contributing factor.
The incidents towards the end of events were more commonly novice to intermediate drivers. In addition to fatigue, dehydration, and sleep deprivation, I suspect that pushing harder to get in some "best laps" before going home was also a common factor.
#36
As to balancing the front per separate posts on Crawford wing it isn't necessary however the cup front theoretically has added downforce vs GT3 OEM.
As to fatigue and last session, I have always believed in my skiing approach which is quit before the last run of the day and I typically dial back the last session just working on line and hitting all the apexes etc. Unfortunately, this day was on the cool side and I hit some lap time targets I had been working on all season which made it challenging to not go for more. I was focused on physical fatigue which was nonexistent vs mental fatigue which clearly was while trying to bring more speed into turns. Hind-sight being 20-20 I live and learn.
#38
You could adjust the swaybars to increase oversteer or decrease understeer, but after testing the Crawford Wing on Track, I've never felt the need to make any further adjustments. The higher and more effective Wing reduces the oversteer on high speed sweepers and the tailwagging on high speed Threshhold braking while yielding a clear view of traffic through the back window. If their are any negatives to the Wing, I haven't found them yet in 3 years and 19,000 miles of Road and Track driving.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#39
I will second FLT's thoughts on Crawford. I added the RS America CF dive planes to my car, as well as a touch of rake to the suspension geo. It fits for my track.
#41
The new door panels eliminate speakers & other weight and makes room to move the cage out.
Plus a simplified version of this to cover the opening when the hvac and double din units come out.
#43
The project is moving along towards my goal of having it track worthy by mid-april.
Pics of Crawford Wing, Covers for headlights (in this case lack thereof), new 19" forgelines with 325 rear and 285 front. A little rubbing on front inner wheel wells on full lock, which won't be a problem on track, but plan is to modify enough so rubbing is a non-issue.
#45
Was down there the other day, coming along nicely! Looking forward to seeing it completed and wrapped.
