991 GT3, GT3RS, GT2RS and 911R 2012-2019
Swapping Seats (?)
Old 09-22-2016, 06:02 PM
  #31
Dr.Bill
Dr.Bill's Avatar
Originally Posted by GT63TT
FS: my two bucket seats. car has 3,500 miles on it. Located in Southern CA. Asking price: $11,000.00 PM if interested. BBi and GMG have both said they're worth up to $12,000.00
Become a member and list them in the classified section. Should sell fast. Although it may kill the resale value of the car. . .
Old 09-22-2016, 06:27 PM
  #32
calpolo17
calpolo17's Avatar
Old 09-22-2016, 07:29 PM
  #33
Banango
Banango's Avatar
Originally Posted by gmgracing
Yes, you can absolutely swap your LWB's for a set of 18-way sofa's.
Upon what is this assertion based?
Having tried to make the swap myself in my 2015 GT3 from the base (4-way electric) to the 18-way seats we found that while the seats fit, what we got was 12-way seats. Most crucially, the lumbar adjustment would not function. Upon investigation we found that both the underseat wiring harness and the seat control module are different depending on the seats originally installed in the car. Further experimentation seemed to show that one can move "downwards" in adjustability from 18 to 4 to 2 way adjustments and get the full respective electric capabilities of the replacement seats, but not in the other direction.
Since I recall that other threads in the past year confirmed my experimental findings, and since I suffer from a fairly severe back problem, I would be most interested to learn that something has changed.
Old 09-22-2016, 11:03 PM
  #34
mwar99
mwar99's Avatar
Shouldn't you be able to get the correct connector and splice it in to get the 18 ways to work right.
Old 09-22-2016, 11:25 PM
  #35
Banango
Banango's Avatar
The correct number of wires are not present in the harness; the entire harness needs to be replaced. It can surely be spliced at some point, but it didn't seem at all trivial. As noted, it is also the module that controls the seats which is different, so not just the connector. When hooked up to the shop computer, the "missing" controls are not simply de-activated, they are not recognized as existing in the way they are on a car built with the 18-way seats.
Again, this is based on experimentation from February and March 2016. Something may have changed. I opted for a more basic solution until my next car.
Old 09-22-2016, 11:41 PM
  #36
ipse dixit
ipse dixit's Avatar
Received 11,529 Likes on 5,056 Posts
This is correct.
Seats are swappable, but you need additional wiring harness and bracket.
  #37
GT63TT
GT63TT's Avatar
I think I will put the buckets in storage and install Recaro CS as they're a middle ground for me. I daily drive the car..
When I sell the car I will reinstall the original seats and bring the Recaros to my next car. This thread has been helpful in getting me pointed in the right direction for my goals. I do plan on swapping my 991.1 GT3 for 991.2 so this is prob. the best route for me.
Quick Reply: Swapping Seats (?)
