Tools for brakejob?
Received 1,155 Likes
Tools for brakejob?
I moved away from my car and took much of my tools with me, so now I need to figure out what tools I will need to buy for a brake job (pads, rotors). I've got all I need to take off the wheels, but what else will I need for removing calipers? What size/shape are the bolts involved?
Thanks!
Thanks!
I am waiting for new longer Spiegler flex lines to be made so they will fit over studs that I will install in the uprights. I will do a DIY just as soon as they arrive. You will need a Torx T55 socket for the Caliper, 10mm socket for the brake line and an 11mm box end wrench to bleed the brakes. I think thats it. I have a brake pad spreader tool but you could use a C clamp.
Yes, I have one and Girodisc is just across the boarder in Bellingham....
Originally Posted by MaxLTV
Thanks! What's the bolt holding that annoying bracket that holds the lines and wires? Is it just regular Philips or something more elaborate?
Your Porsche Parts Superstore
Parts | Tech-Session | Facebook | Youtube
Jason Burkett
Paragon Products - Porsche Parts & Accessories*- 800.200.9366
Tech Session - Porsche Tech & Info*- 361.289.8834
jason@paragon-products.com
Jason Burkett
