991 GT3, GT3RS, GT2RS and 911R 2012-2019
Aftermarket Lift kit for 991 Gt3
Old 07-23-2016, 09:47 PM
gtdrei
gtdrei's Avatar
Default Aftermarket Lift kit for 991 Gt3
Hi Rennlisters. Shopping for a 991 GT3, and due to the severity of my driveway, (click on my profile pic) have limited my search to those with factory front axle lifts.. Anyone here have any experience with aftermarket FAL systems?
Robin
Old 07-23-2016, 11:33 PM
ipse dixit
ipse dixit's Avatar
Received 12,175 Likes on 5,292 Posts
I don't believe there's an aftermarket option for the 991 GT3
Old 07-24-2016, 12:45 AM
dark knight
dark knight's Avatar
u can t add it, it under the chassis, its an aircylinder thats way deep inside
Old 07-24-2016, 02:20 AM
0-60 freak
0-60 freak's Avatar
I have the cleanest 15' gt3 out there, 1034 miles, mo track, no rain, has lift. 148k
Old 07-24-2016, 09:37 AM
bronson7
bronson7's Avatar
Robin
If your driveway entrance is that severe are you even sure the lift will help? After all, the lift only raises the front end up just over an inch. If that concerned, do you know somebody that has one you can test?
Old 07-24-2016, 12:32 PM
CAlexio
CAlexio's Avatar
Received 1,976 Likes on 919 Posts
I second the need to have someone test it for you.. All the measuring in the world using info from this helpful forum didn't help in real world with my garage.. Ended up having to get a separate one when I finally bought car home. It's all about approach angles, and not having too many different ones close together or they (the angles) will conspire against you.
Old 07-24-2016, 10:42 PM
Mike in CA
Mike in CA's Avatar
Actually, the lift feature is integrated into both front struts which are configured differently than stock, with a chamber that is pressurized by a pump and regulator assembly. I believe it's possible these parts could be retrofitted to a non-lift GT3 but a) Porsche might not make them available for car that didn't come with a lift from the factory and b) in any event it would surely be a mega-expensive exercise; probably cheaper to build a new driveway.
Old 07-25-2016, 09:50 AM
Porschekalle
Porschekalle's Avatar
KW and also Techart have an aftermarket solution for you .. I have the Techart version installed in my GT3 and I'm happy with it
Old 07-25-2016, 02:21 PM
ipse dixit
ipse dixit's Avatar
If you are talking about this one from Techart, it does not appear to be available for the 991 GT3.
My god, it's also $7k, even after a discount. Makes the OEM system on the 911 for around 3k, seem like highway robbery.
Quick Reply: Aftermarket Lift kit for 991 Gt3
