991 GT3, GT3RS, GT2RS and 911R 2012-2019
GT3 RS Exhaust Options
Old 06-09-2016, 09:41 AM
  #31
Waxer
Waxer's Avatar
That's just great. Now my wife will have to start watching this thread.
Old 06-09-2016, 01:20 PM
  #32
RSSmike
Former Vendor
RSSmike's Avatar
Post RSS X-Pipe GT3/RS
RSS X-Pipe GT3/RS
Old 06-09-2016, 05:29 PM
  #33
CDinSing
CDinSing's Avatar
Two friends have SW rear bypass using the std exhaust tips. With Open valves, their cars sound higher pitched and Ferrari like in comparison to my GMG. It has larger outlets that fill the center section better ( personal preference) and it also has a deeper growl. They both sound good just different.
Old 06-10-2016, 01:48 AM
  #34
OCturbo
OCturbo's Avatar
Originally Posted by Biglife
How would you describe the exhaust note? Also, where'd you grab it for $800?
I have the same exhaust (Mbrp) on my gt3. It has a deeper and throatier sound compared to sharkworks or stock exhaust. It sounds great. Try Vivid motor sports for the best deal. It's powder coated in black, has larger exhaust tips (4 in), and weighs 12 lbs vs 20 for stock muffler. The exhaust tips stick out a little more than stock, but gives it a more aggressive look.
Old 06-10-2016, 10:35 PM
  #35
Mvn1971
Mvn1971's Avatar
Originally Posted by 16'991GT3
Do you guys have sound clips of it?
I will work on this weekend!
Old 06-10-2016, 10:41 PM
  #36
Mvn1971
Mvn1971's Avatar
Sounds awesome and great build, using really solid material. Some of the other ones are much thinner and believe when I tell you, my friend and I bought exhaust bypass from a very reputable company for our 997 GT3s which were using thinner material and we both develop burns hole right thru the roof of the bypass.
Old 06-10-2016, 11:44 PM
  #37
GONFST
GONFST's Avatar
I put the Akra Evolution system on and couldn't be happier. Build quality is without comparison and sound quality is awesome. 30+ lbs savings on weight. I do not have before and after performance data.
I have been adding Akra systems to my bikes and cars for the past 12 years...never had an issue and always pleased with quality and sound.
If you are looking for LOUD, Akra is rarely the system to go with...they tend to produce a nice quality sound that is louder than stock, but not extreme.
Old 06-11-2016, 12:32 AM
  #38
786
786's Avatar
Originally Posted by madmurdock
Yes, please do let us know who gets a rose.
lol
now that you've been inundated, looking forward to seeing what you go with Serge
Old 06-29-2016, 10:21 PM
  #39
soulsea
soulsea's Avatar
Received 1,810 Likes on 533 Posts
So I think I have it narrowed down to the GMG and Sharkwerks center exhaust bypass systems.
I've been told that deleting the side mufflers isn't advisable because apparently doing so robs the car of torque. Yet there are systems from very reputable vendors like BBI that do just that so I'm not sure what to make of it. Maybe one can remove either the center or the side mufflers without affecting the torque but not both? I just can't make sense of it.
Anyway, assuming I go for a simple center muffler bypass, is there a way to make the valves in the side mufflers stay permanently open? I want the sound to be consistent along the rpm range, and from what I gather, even in Sport mode there is some valve interference up to a certain rpm threshold. Is there a trick to keeping them open or some widget that one can buy to achieve this?
Thanks.
Old 06-29-2016, 10:36 PM
  #40
FJSeattle
FJSeattle's Avatar
Thanks.
Support your local dealer. If you don't like it, try another one. It's just an exhaust.
With that said, all options besides headers are for sound only. So if that's the case, at least eliminate the side mufflers to drop weight and heat. If you want to keep the valves, choices get narrower and require a full header system.
Nothing more money can't solve.
Old 06-29-2016, 11:04 PM
  #41
0-60 freak
0-60 freak's Avatar
Originally Posted by AC SATCO
GMG
+1 GMG all the way....
Old 06-30-2016, 12:11 AM
  #42
786
786's Avatar
Serge, talk to David. He has GMG bypass and catless headers, car sounds ridiculously good. Best GT3 I've heard.
Maybe he can send you a vid clip.
Old 06-30-2016, 02:03 AM
  #43
Guest89
Guest89's Avatar
Thanks.
Serge,
Every vendor is a snake oil salesman to some extent (just wait, one of these guys will attempt to subtly discredit me for saying this).
My opinions:
Sharkwerks - Best customer service by a wide, wide margin; had their bypass on my 997.
GMG - Pricey vs Sharkwerks, but I bought mine used; I prefer the sound of GMG vs Sharkwerks on both 991 and 997. GMG is deeper tone, SW rips at the top but sounds less aggressive overall IMO. GMG customer service is better than it used to be, and it's not like much will go wrong with a ~20" long steel pipe anyway.
You can "unplug" the lines that actuate the valves so that they are forced open at all times.
If I were a baller like you I'd go all in and get a Dundon Motorsports setup, though.
Old 06-30-2016, 02:16 AM
  #44
kyrocks
kyrocks's Avatar
Here's my CMS exhaust from someone's iphone. Imagine what it sounds like inside!
Old 06-30-2016, 11:52 AM
  #45
786
786's Avatar
Prally.
Quick Reply: GT3 RS Exhaust Options
