Advice Needed: LWBS Sticker removal
Howdy....
Before I go at it and try to peel the stickers off, any advice or suggestions from those who have done it?
My hope is they just peel right off and don't pull apart and no adhesive left on the seat backs. Obviously want to keep away any solvent cleaner of any type that would hurt the clear coat.
Is it as easy as it looks?
I had my detailer take them off. He said very easy to do but not sure what he used to remove it. Some one here will give you some good advice on how to do it.
My dealer has done this during PDI,but I can't imagine it to be difficult. You are removing a sticker from over a glossy surface. The carbon fiber has clear coat applied on top of it,so IMO,you can just remove those stickers spraying some warm water to soften them up. It's not like trying to remove a sticker from leather or alcantara,which can be a bit more challenging.
Removed mine when I first got the car. Get a corner to come up and you can slowly pull them off. I used rubbing alcohol and goo gone to help remove/lift the stickers, plus remove any glue residue.
Proceed with caution. I spent about an hour+ getting mine off my 18-ways recently. I followed instructions on other threads here describing a process where you soak a paper towel in 93% isopropyl alcohol, lay it on the sticker for a period of time (10-20 minutes I think) and then start peeling it off.
First, those stickers adhere like they were put on with gorilla glue. They clearly don't want them coming off, ever. When you are able to get a corner started, it will not come off in one piece when using any method I came across here. Instead you will end up pulling it off in fragments, and leave a good amount of residue behind. Maybe if it was a warmer day, or I used a heat source to soften things up, I would have had a better result. In the end, you can't tell my seats ever had a sticker on them, but it took a lot of time and patience. If you can find a detailer who confidently says "Yes, done this many times", I'd turn it over to them, or at least ask about their method.
A heat gun or blow dryer on low always helps soften the adhesive, then peel up at a 90° angle or less, not back onto itself.
If that doesn't work try a right angle grinder.
I used a blow dryer to heat it up and then it peeled right off. For the excess, I use masking tape and take it off little by little by applying the tape to the remaining residue. Took about 10 minutes. I would avoid WD-40, if you don't want your car to stink.
Lifetime Member
Lifetime Member
TT
Thanks guys. Will get out my heat gun and take it slow and easy. That has worked fine before on decals on exterior paint. Nice to know folks have used it on the seat backs.
RayDBonz is right - getting decent access in the back is the hard part.
As Kobalt said - who exactly is supposed to read these stickers? And how did they get back there?
If none of this works out, I'll try the grinder. Maybe be really, really careful with the cut-off tool.
I removed this from back of GT3 which was the cheap plastic not CF and I could always see residue of the glue in the paint. The glue they use is nasty. Don't freak out once you get started. It may look easy but you be surprised.
