Cutting the Passenger Seat
Now that I have the Cantrell roll bar installed, I looked at the seats to see what needs to be done to install the 6-point harnesses. The Driver's seat has the slot in the fabric and through the seat shell, so that's easy.
The passenger seat has no such hole in the fabric or the shell. Cutting the shell is not the part I am worried about. Do I have to cut the seat cushion open and re-stitch the respective sides closed to create that slot? I am much better with a wrench than with a sewing needle. I am sure others have done this surgery already, but I couldn't find it using search. Happy to be pointed to the right page if it's out there.
Yes you cut it and yes it's easy:
https://rennlist.com/forums/991-gt3-...passenger.html
This thread tells you everything you need to know- Cantrell can do it too.
Some regions in PCA might be a pain to deal with on the seat. Mine, OVR, would be reasonable. Take photos to show how it looked prior to and after the cut. If you have a couple of regions you typically run with ask their safety chair about what you are doing.
I didn't do any sewing on the passenger seat - just open it enough to get the straps through and everything tucks back together very nicely. I followed the post from OrthoJoe without any surprises.
A note: I disconnected the battery before pulling the seats - if you don't you will get an airbag error light that the dealer will have to reset.
That is ridiculous- let's be logical, you are removing some thread so you can slip in a center sub belt(s) to run a 5 or 6 point harness which is a much safer passenger restraint. To be fair you are cutting a hole in the seat bottom also, but that is no different than the drivers seat. No decent tech inspector would ever say that is not allowed because the seat is 'modified'. If they do, you need to run with other people- some groups and regions are run by nerds that only can follow the rules, and not the 'spirit of the rules' or follow any logic.
