For those who disconnected exhaust valves...
Hello...
Did you simply disconnect and leave hanging?
I'm guessing their vacuum actuated.....? If so I would think its best to cap them off.
Did you leave them disconnected?
It seems that even with the PSE button on they still are closed at lower RPM's as it seems to get really loud around 3500-4000 RPMs. Unless that's just the sound profile of the engine...? This is my first Porsche / flat 6 engine.
Any insight is appreciated. Thanks!
They are vacuum actuated....you definitely need to plug the lines if you disconnect them. It's also a good idea to put caps on the valves themselves to keep out dust and moisture. Know that with the 991 GT3, unlike previous models, the valves are ECU controlled to optimize torque. I ended up returning them to a stock configuration after about a week.
Yes, you cap them. The sport exhaust is controlled by the ECU and does close from just above idle to 3700+/-rpms. I had mine disconnected with Sharkwerks but reconnected them with GMG. Don't really like the opening and closing but do like the less sound on the highway. Also I like the that my sport button is functioning.
Got it. I understand the back pressure benefitting low end TQ.
I've got the Fabspeed headers, sport cats, and side muffler bypasses with stock center muffler. However, I'd like some more grunt / volume at lower RPM's.
So before I purchase a center muffler bypass I'd like to hear/feel what the disconnected valves are like.
Thanks all.
Thanks all.
I've gone from SW center bypass, reinstalled OEM and removed side mufflers with fab speed bypass all in the quest of noise!!! I plugged and capped the vac lines from day 1. Slightly annoying that the PSE button is defunct now.
I'm sure you've seen the IPE full exhaust system that comes with RC that allows adjustment of valves? You can keep them open, closed or allow the ECU to open/close. I'm considering this option but there are a lot of IPE detractors on RL due to quality issues and a screwed up early dyno run that showed a large HP loss with the exhaust but believe that error has been corrected. Anyway another option/consideration and as always YMMV.
Thanks all.
Thanks all.
Granted...I have yet to take a long road trip on the highway. Sooooo.......
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
FVD offers T316 steel and Akrapovic Titanium made
much more reliable
much more reliable
Definitely worth testing. Had my mechanic not talked me out of it 3 or 4 times, I would have done it. I may still try one day so if you do, please report back.
