Who is using "Paddle Neutral" function to improve their lines on road and track?
Interesting. I don't know if I could master it but I'll try it.
As for running with driver aids off, for me it is substantially faster. I find that the car and I correct at cross purposes with everything on so I actually end up more out of shape when my correction is opposite lock and the car grabs a caliper and cuts power. Now I might be able to really be super duper smooth and gentle, but right now I'd say it's probably over .5 sec per mile I lose with ESC/TC. YMMV
I've only played with it....boy-racer throttle blips....and, like Macca, once in a while to smooth downshifts when coming to a stop. I haven't had a situation autocrossing where I thought it might help but maybe will try it out next season just for grins.
i was interested to read this, i have only completed 12 track days so far, relying on the protection afforded by the nannies but i had assuming the track veterans would be running with ESC/TC off.
kick in , I'm sure there other opinions that there controlling brakes and power without ones perception
I don't think paddle neutral will have a benefit to my times at the track as its a messy way to get through a corner but I was curious if others had used the feature as in early launch media there was much talked about "hooligan mode" but not much since. Can't see why they incorporated it as a special function of PDK-S if it doesn't have a reason.
Platinum Dealership
Well, maybe hooligan mode is enough of a reason. my comment about running with nannies on/off is that in that case my car control or self awareness actually keeps me below the threshold of making mistakes in the car. I am always ESC/TCS off in all cars except the P1 even on the street and definitely even with the P1, Viper and 675LT I am ESC off etc on track.
Running my race cars on slicks with zero TC you have to develop the feel to know when you are pushing too hard- it allows me to be more patient with myself because I inch up to the limits.
With street cars on road legal tires, (pirelli, michelin, etc) when you are on the track you can hear which layer of tread you're sliding on by the pitch of the noise. The various layers of rubber make different noises as they peel away from inside edge towards the outside edge. This allows you to basically hop into a brand new car and know what kind of side load/lateral G or slip angle the car can handle without fully spinning and breaking loose.
I'm basing this on those on this board I keep regular with on track work with the 991 GT3. Manifold, Joe, Peter etc plus a number of European track junkies such a Philgv, Manuel etc. I've studied my in car footage and the wheel speed traces from the Aim telemetry in my own car and can say the only time ESC/TC kicks in is in the wet or when I do something dumb. I don't see myself saving any time at my local track with it off and have kept it off for a few sessions to compare. I'd leave it off more often but for the fact it's another series of buttons to remember to push. However in order to experiment a bit with paddle neutral I'll definitely leave it off next time.
As for the clutch-in feature, I remember a video with the Preuninger where he basically said it was to allow for clutch-dump rotation as a way of getting the car into a drift. Basically for shenanigans as you could do with a manual.
The most seasoned drivers will not be driving with aids on - if they are trying to maximize the car's potential. Some new factory race cars do have TC and ABS as standard and should be run with them on, but these are not street calibrated systems and also offer a significant amount of tuning to adjust to driving style and track conditions. The quickest way in non-extreme conditions is with these systems off or set to minimum.
Regarding the clutch dump to rotate the car: it seems an odd tactic to me. It's not something I would regularly do in a car with a real clutch, so why would I want to do it in a 991? Perhaps to avoid a spin maybe...but to rotate the car you want more weight forward in tight low speed corners, so brake/trail brake is more effective than neutral tranny. Left foot brake and throttle combined would be far more subtle and controllable than dumping the clutch IMO. Will have to play with it when my RS arrives though
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,503 Likes
Pro told me to leave ESC/TC on in this car, so I do. Only time I've noticed it kicking in is when I got too greedy with the throttle in tight turns. I tried them both on and off on a wet to semi-wet skidpad, and found that they don't intervene until the car is way out of shape. And when it did intervene on the skidpad, it was quite effective, though on track I know of a 991 GT3 spinning with them on, so beware, YMMV. But I find that I can play around with the car a good bit even on track without apparent intervention from them, and I observed the same when riding with another really good 991 GT3 driver who left them on. Leaving them on gives me confidence to push harder, since there's a safety net there which might work, but I also recognize that it might not, so I do try to avoid f'ing up.
In my 997.1 C2S and Cayman R, I turned ESC off on the track because I did feel that the threshold for intervention was too low.
I briefly tried tracking my C63 sedan also - just for a little fun - and found that the ESC intervention was so intrusive that it was screwing me up, and I felt much safer when I turned it off.
I forgot we had the paddle neutral function until I saw this thread. I suppose a big rotation at corner entry might look faster, but I have doubts that it actually is faster.
