Brake Squeeel
Could you please answer the question, its a known fact that these brake pads squeal at low temps and there is not much one can do about that but change the pads, alternative recommendations pls ?
Many of our clients use a designated street pad that also works for light track use, and used a track pad on the weekends. I know this is not the most convenient solution but it is one.
The pad we recommend for that has great street characteristics as well as perform well with light track use. They produce very little dust and no squeal.
I have an attorney friend. He once told me of a client that bought a new TTS and complained of brake squeal. The dealer couldn't fix it, so he lemon-lawed it. Successfully.
Some people...
Some people...
& these part numbers are exactly which, from whom ? aren't you supposed to be selling parts or is it a secret ?
I should have mentioned it. I thought I did before but it was in another thread.
The Pad I am referring to and recommend is the Race Technologies TS20.
We have them stocked for most applications
The TS20 is a great dual purpose pad. It combines an aggressive initial bite , good heat resistance all while keeping dust and noise to a minimum.
