Giro Disc Replacement 2-Piece Front Rotors
Basic Sponsor
Competition Motorsport is glad to announce that Giro Disc has begun producing replacement 380mm front rotors for the 991 GT3. They are finishing anodizing the hats as I type and will have them available for delivery beginning the week of the 23rd of November.
The new 380x34mm Giro Disc front 2-piece floating rotors weigh 23.4lbs (marginal lighter than the 24lb oem units), but most importantly they are slotted rather than cross-drilled and will provide significantly longer life than the oem parts, especially under moderate to heavy track duty.
We have requested a large portion of their limited first run, so if you would like to replace your cracking cross drilled oem rotors for a set of the Giro Disc slotted, drop us a note and we will appreciate the opportunity to earn your business. Or you may find them on our website here;
http://www.competitionmotorsport.com...2014-A1146.htm
