Kobalts Great White RS
#331
The front pads (Original Porsche, first set): Almost no tapping.
The front pads had about 3.5-4 mm left. Maybe 0.5 mm tapping in longitudinal direction.
The rears where at 8-9 mm. Taping 0.5-1 mm aprox.
#332
I also installed cup studs in the front and Tarett 85 mm studs in the rear.
Removed the brake wear indicators. Tied them up.
Next step is to install these to make changing brake pads even easier:
https://rennlist.com/forums/991-gt3-...ard-lines.html
#334
There where about 8 mm left on rears and 3.5-4 mm on the fronts.
"I've never mixed pads"
I've even mixed PCCBs with steels - that works OK too
#335
#336
#337
They fade way to fast! Around 50% they are finished.
And I don't mean that they brake less, I mean they are totally "garbage".
I throw them away because it was simply not fun to drive with that much fade!
On rear, they are holding due to less heat. I think the T° difference between front/rear is something like 100°C .
I will put some paint temp and check this tomorrow!
#339
Installed a Cheapo-Rear View Camera on the Audi Transporter. It is turned on by the makeup mirror in the passenger sun visor. Simplest possible installation
Really nice to see the cars behind instead of a 991 GT3 RS in the rear view mirror.
#340
Thx
#341
It is as simple as possible: It is just a rear view mirror with a 5" LCD integrated that is clipped on to the original mirror.
Then i get the power from the makeup light.
I tried wireless transmission first but I got interference, not very bad but annoying.
*Note that this is not in the Porsche but in the Audi Transporter
Camera
https://www.amazon.com/Esky-EC170-11...amera+wireless
Mirror
https://www.amazon.com/Intsun®-Vehic...rror+Monitor+5
This was the wireless system I tried but didn't use:
https://www.amazon.com/Zettaguard-Wi...XXZSMMB3F2F55Q
#342
At Nürburg after a long dag on Autobahn.
37 degrees Celsius at most made the Audi sick.
We missed the tourist driving and of course "It was amazing" according to those who where there.
Attachment 1084148
Attachment 1084148
