Look what I got from FVD today!
Is it a must to remove rear bumper to do this mod?
Did you consider center bypass as well or would that turn it into a street obnoxious monster (not to mention a cop magnet as well!) Txs.
No because it's just one pipe from the side bipass going right into the center muffler. The entire mechanism that sits on the upper pipe from the stock muffler is gone. I didn't as I never drive the car without the PSE on.
The rear bumper is litter 4-5 screws, takes 2-3 mins to get off, but yes, you need to take off the apron/cowl to get to the side mufflers to remove them. The hardest part was actually getting the bolts off the studs that held the side mufflers to the center muffler. Everything else was incredibly easy.
In retrospect, I should have taken off the center muffler along with the sides and then removed the sides from it, when it was off the car. The angles were incredibly awkward and the studs coming out of the center muffler are fragile, I broke two.![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Not sure the layout of the sharwerks but possibly it makes it much easier to get to the bolts and unscrew the pipes from the sides mufflers off.
To get the side mufflers out; the bumper needs to come off. Getting the bumper off is really easy. Adding the center muffler would essentially be straight pipes after the cats. In California I'd get pulled over in a flash.
notice any power/torque loss?
I'll totally agree feels like more the car is more responsive. Is it the 40lb weight loss? Is it the actually more torque? Or just does it just "seem" like more because the sound is so much better. It's hard to tell except, the new symphony of sound is great.
![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
Just got mine installed as well. A little surprised to be charged $300 for install (2.5hrs labor) but happy with the results!
Just a short drive home so far, but echo the reports above about a deeper, louder sound at lower RPMs and an altogether more exotic feeling. Woo!
Interestingly, the more consistent sound through the rev range actually sounds more "natural" to me and probably what it should sound like from the factory!
My pipes are installed with the FVD plate facing down like above. Definitely no resonance vibration and actually much LESS drone so far than with the side mufflers in place but valves disconnected. Yay!!
hi, newbie here, just a quick ask, what do you people who have these pipes fitted do with the silencers, would anyone like t sell them?
I am looking for some replacement parts.
Many thanks, Carl
Many thanks, Carl
J/k should my estrogen levels start to raise I very well might put them back on.
![typing](https://rennlist.com/forums/graemlins/yltype.gif)
Just installed mine. I love them!
However, did anyone else have a really hard time putting the doughnut gaskets on the fvd pipes? I had to literally hit them onto the pipe to fit.
