FVD Brombacher Bypass Exhaust
Hi guys, Does anyone have any experience or knowledge of this product? Its a bypass just like th SW, GMG, Etc just curious if anyone has any feedback.
FVD uses 316 which is better for corrosion resistance.
I'll have a full FVD cat-back in the next few weeks. It will include new side mufflers, valve delete, and center section. My requests are as drone free as possible and lack of rasp. We'll see very soon.
To get in you would need:
1. A CNC mandrel bender
2. A tubing expander, segmented or bull nose
3. A laser or die to make the plate
4. TIG welding equipment
5. Tube cutting equipment for the angle cuts
6. A jig to hold the parts for assembly
7. Notching equipment
8. The time it took to develop the part
Then there is the waste on start-up each time a run is initiated. It's highly unlikely that a bender will produce the exact same part to fit the jig without some tweaking from run to run. Unless you are buying large lot quantities of tubing from your supplier you will be forced to deal with variances in the incoming tubing mechanical properties which is going to change your setup and produce more scrap. And some days your welder just has a bad day.
Money - I believe you have a rear bypass?? I thought you were going to replace the OEM side mufflers with the FVD and see how it sounds??
FVD was not yet available and I am impatient. I really do not think you can go wrong with SW, FVD, GMG.
I really do love the SW 100mm tailpipes. They certainly are far more pronounced than the OEM. I am also convinced that the larger tailpipes do notch up the volume slightly more - it could be in my head though
As long as you believe it sounds better, who cares if it actually does sound better.
Just ask Messrs. Harvey Fletcher and W.A. Munson, they'll tell you.
On Apr 8, 2015, at 2:49 PM, Rhonda Roxburgh <Rhonda.Roxburgh@fvd.net> wrote:
Matt,
Just wanted to let you know that M&M has shipped your mufflers and center bypass today. FVD Germany will receive them on Friday the 10th and will ship them out via airfreight to us.
We should have them no later than Tuesday the 14th so you should see them on Wednesday the 15th.
I will be checking on them personally and getting accurate weights for you. I will email you the pictures of the mufflers on the scales, etc.
Thanks,
Rhonda
-----Original Message-----
From: Ingride Ernst <ingrid.ernst@fvd.net> [mailto:ingrid.ernst@fvd.net]
Sent: Wednesday, April 08, 2015 9:37 AM
To: ***** Brombacher; Rhonda Roxburgh
Subject: Neue Lieferzeit
FVD-Faktur
Neue Lieferzeit
Druckzeit:08.04.2015 / User:Ingride
Artikel Nummer : BES 991 040 60S
Artikel Name : Schalldämpfer "Brombacher" 991 GT3 ohne Klappen Alte Lieferzeit : 08.04.2015 Neue Lieferzeit : 10.04.2015 Offene Bestellung Nr. : 15-04140 Kunde Nr. : 0008000
FVD-Faktur
Neue Lieferzeit
Artikel Nummer : BES 991 070 60S1
Artikel Name : Mittelschalldämpfer -Bypass" Brombacher " 991 GT3 (1-Eingang) Alte Lieferzeit : 06.04.2015 Neue Lieferzeit : 10.04.2015 Offene Bestellung Nr. : 15-04629 Kunde Nr. : 0008000
Matt,
Thanks,
Rhonda
FVD-Faktur
Neue Lieferzeit
FVD-Faktur
Neue Lieferzeit
