NAV-TV users - how to force rear camera on?
I'm about to have a front and rear camera NAV-TV system installed. I read the installation instructions and they describe how force the rear camera on, but this requires tapping the steering wheel mute button twice, but this button is not installed on 991 (but is on other Porsche models).
On 991 models you can press the volume **** to mute. Will pressing the volume **** twice activate the rear camera? If not, is there another work-around?
I realize the backup camera will activate when the car is put in reverse. What I'm interested in here is to activate the rear camera when moving forward.
Double tap the defrost button
No front cam. Just rear.
Also, make sure it's a deliberate double tap.
In other words, tap (see that the light comes on to show defroster activated), then tap it deliberately again (so that the light goes off to show defrost deactivated), and in about 1.1 seconds, the rear camera should pop up.
It's either 1.1 or 1.3 seconds.
http://app.navtv.com/media/products_...3.1_Cam_r6.pdf
I had it installed professionally by someone other than me. I can barely handle an electric shaver without doing permanent damage to my ugly face.
Took about 2 hours to install.
I have the multifunction wheel, and for some reason the double tap is WAY too easy to trigger.
If I mute and unmute within 15 seconds of each other, the camera comes on.
I've contacted NavTV to see if there's a way to adjust this, it seems wrong as the manual indicates it must be within one second.
