Starting 991 GT3 in Winter
Snow is on the ground and my GT3 has not been driven for 2-3 weeks now. Being they put a ton of salt down in my area the car will remain parked until we get rain to wash the roads down which most likely won't happen till spring.
Is it wise to start the car and let the engine idle up to operating temperature and give the car a few revs etc... or is it best to let it be till I can actually drive it?
You MUST let it warm to operating temperatures. This burns off any condensation. The whole engine heat cycles and cools properly.
Condensation in the oil is evaporated by the oil temp heating up.
The oil also lubricates the moving parts in the engine and gives a fresh film in the cylinder bores.
As for driving, it would be good for transmission and bearings but the bad is the road salt/brines/calcium chloride etc.
I would not drive til you are able to with clean roads.
Although the car can handle salt for the time frame that most people own the car.
yes, the issue as I understand it...just starting up the car and letting it warm without driving it under load allows water condensation buildup in the oil that does not have time to evaporate. That is how I understand it anyway.
Sent from my iPhone using Rennlist
The best is to start the car every month when sitting.
I also start the car every few weeks and bring it up to temp. Today may be warm enough though for a little spin!
I use a Porsche battery maintainer year round. More to protect and extend the health of the battery than concern about starting/not starting. I can easily get 6-8 years out of a factory Porsche battery.
It's plugged in the entire +5 months of winter hibernation.
