California Duster
California Duster
Anyone using them to remove dust after a drive and between washes?
Will leave small swirls and scratches if you get anything trapped in the fibers. Also not compatible with synthetic polishes because the tips are dipped Ina bit of wax. Works best if your car has carnauba on it and you keep it fairly clean all the time.
Yes, works fine, cleans dust off and if part of a daily routine is harmless. Seen at car shows everywhere, I've used one for years with no ill effects and never has it caused scratches, but you must use it very lightly and shake any dust off you can. Common sense don't use it to clean a really dirty car- but great for keeping a dark car looking great, my routine is to use it then touch up with detail spray.
Love it ........use after each drive, and it keeps my cars spotless. I only use carnuba wax and polish. I'm a freak my cars get waxed weekly. Also once I dust it a quick 5 minute spray wax; been doing this for 20 years no issues and paint looks new for years.
Received 5,413 Likes
Car must be cool.
Sent from my iPhone using Rennlist
My former garage neighbor has a black C6 corvette that is spotless with no scratches, swirls, chips. He says he doesn't speed in it, and I believe him.
He doesn't take the car out for a wash. He just uses a California duster after each drive, lightly dusts it off, then applies Griots speed shine (or maybe spray on wash if really dirty) and wipes down. Claims the car doesn't have wax on it either as he hates silicates.
I picked up a small and large version of the duster, but personally find it more fun to do a full wash.
I've been using the duster for years. I keep two. After one gets dirty I use it for the lower part of the body and use a new one for the rest of the car. As the new one ages and builds up dirt I switch it to bottom duty and get another new one. This is about a yearly cycle of buying one new duster. I dust the car after every drive.
I think using it or not depends on where you live. Living in sandy areas like FL or AZ, you probably shouldn't use it. Personally, I say no to a duster.
If that guy with the black Corvette is wiping his car down with a duster and Speed Shine with nothing on the clear coat, I guarantee you I'd find a boatload of scratches.
I am a recovering detail addict. Anything that puts dust/grit/sand, no matter how small, between the paint and a brush then rubs it, is not a good thing. Car cover is the same. However, if you are keeping the car clean enough, or using multiple dusters, or simply don't car about fine scratches you cant easily see, then it works great. To me, the perfect application for a California duster would be a garaged car, that is waxed using carnuba, and kept relatively clean, using a spray detail product with a fine mist, then the California duster. But then, I am more than a little OCD on this topic
I prefer something like this, which creates static as you twirl it, to lift dust. Vs using fibers that rely on coated wax to do so. You may have seen some of these at major auto shows. There are several companies that sell them in the U.S. also. Just search on car detailing duster natural.
http://www.chemicalguysuk.com/Dust_M..._p/dustmsm.htm
or
http://www.elitecarcare.co.uk/dodo-j...ing-duster.php
I think using it or not depends on where you live. Living in sandy areas like FL or AZ, you probably shouldn't use it. Personally, I say no to a duster. If that guy with the black Corvette is wiping his car down with a duster and Speed Shine with nothing on the clear coat, I guarantee you I'd find a boatload of scratches.
I don't think using anything like a California duster is good for the paint. Might as well wipe down with a dry microfiber towel - should be a similar result. Just my opinion of course, I don't have the cojones to use one on my cars.
