991 GT3, GT3RS, GT2RS and 911R 2012-2019
Ideal Brake Kits for 991 GT3
Old 11-20-2014, 08:15 PM
  #46
RacingBrake
Former Vendor
RacingBrake's Avatar
Originally Posted by brass4321
I would be interested in the CCM-X upgrade for my non-PCCB setup.
Those CCM-X rotors are designed and built by RB using Surface Transforms' CCM-X discs:
400x34 front (vs OE's 380x34)
390x30 rear (vs OE's 380x30)
This CCM rotor set up will retain your OE calipers with spacers which will be included in the package for a bolt on installation - The most affordable alternative.
We believe this option will be a good alternative for GT3 owners who don't want to pay high cost of factory pccb and with great concern of future high replacement rotor cost, yet still can enjoy the benefit from the light weight CCM rotors, and swap with factory iron rotors/pads to optimize your driving needs - Street or Track.
Thank you.
Warren-RB
Old 11-20-2014, 10:17 PM
  #47
RacingBrake
Former Vendor
Front CCM Rotor:
Rear:
Old 11-20-2014, 10:20 PM
  #48
brass4321
brass4321's Avatar
Group buy anyone?
Old 11-20-2014, 10:40 PM
  #49
Lodi
Lodi's Avatar
How will the CCM-X wear in comparison to factory PCCBs? Have heard that the PCCBs are holding up very well, even with extensive tracking. What is involved in replacing them? Do you buy another kit or is there a lesser cost based on initial ownership? Thanks in advance for the info!
  #50
brass4321
brass4321's Avatar
What kind of brake pads come with the kit? Do you provide a warranty?
Old 11-26-2014, 07:37 PM
  #51
RacingBrake
Former Vendor
For street driving I would say pccb and ST should make no big difference, but for track applications (especially for heavy tracking) due to different type of construction ST rotors will definitely be stronger and work better in terms of delivery of brake torque, and wear under the extreme temperature.
Initially you would have to purchase the complete rotor assembly, and only the replacement rings when the rotors wear out.
Old 11-26-2014, 10:35 PM
  #52
brass4321
brass4321's Avatar
I thought that one of the biggest benefits of CCM is that they don't wear out? Aren't the pads supposed to be the only consumable part of a CCM setup?
Old 11-26-2014, 10:54 PM
  #53
brass4321
brass4321's Avatar
Default Are the stock red calipers the same as the yellow PCCB?
Did you ever confirm whether the stock red Porsche calipers are the same as the yellow PCCB calipers?
If they are the same, wouldn't it be possible to install the larger direct replacement 410mm and 390mm ST rotors with the stock red Porsche calipers? What else would be needed to do this? Spacers?
GT3 with standard brake:
Reference from 2014 GT3 Suspension Overview by Elephant Racing
Front:
Rear:
From the pictures the calipers for the standard brakes (iron rotors) appear the same as for PCCB except in color.
RB calipers are offered as an improvement to OE calipers not just for quick pad change but also the performance gain.
The front caliper will be a direct bolt on, while the rear will use an adaptor Both front and rear calipers are to be available shortly.
Old 11-27-2014, 10:36 AM
  #54
RacingBrake
Former Vendor
The caliper offset is not the same, but we can change the hat design to fit the red calipers.
Old 12-01-2014, 08:41 PM
  #55
RacingBrake
Former Vendor
Please refer to this thread for Standard brake (Iron rotor) upgrade option to CCM rotors here:
https://rennlist.com/forums/991-gt3/...-non-pccb.html
Old 05-21-2024, 01:35 PM
  #56
Article_Auto
Article_Auto's Avatar
I have a base 997.1 Carrera.
Would it be possible to upgrade to the 991 caliper with an adapter to run GT3/GT3RS/Turbo PCCBs?
Old 05-21-2024, 03:58 PM
  #57
Tom@TPC Racing
Premium Sponsor
Tom@TPC Racing's Avatar
Would it be possible? Yes.
You would need someone to custom make you a pair of adapter brackets to go from 130mm to 225mm spacing, and with the correct offset.
IMO, it would be easier to change the front uprights to 997 S and then add 997 Turbo PCCB brackets.
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
Quick Reply: Ideal Brake Kits for 991 GT3
