G Forces
The manual does speak to the relationship between temperature and pressure and how the TPM race circuit mode is useful for monitoring pressure as the tires heat up, so maybe that's what the article you remember was referencing, but there is no actual tire temp function.
Guys I have a couple of questions for those who had the brief time with the car before the stop order
What's the deal with TPM, has a track mode feature? can you monitor psi as you are driving on the track?
And what about the electric parking brake ? does one have to manually turn a switch for it on?
I only have 5 plus months till I can find out for myself.
Yup, the TPM track mode feature lets you set and then monitor pressures on track that are different from the street pressure settings. Basically you adjust the tires to your desired pressure, enter it into the computer, and it's monitored from that baseline. Tire pressures are updated in the "Circuits" display every 5 seconds for 15 minutes.
The electric brake switch is a broad toggle switch at the lower left corner of the dash. You push it to set it. To release, you pull. Or if you are belted in, door closed, and with the engine on, when you press the throttle to drive off it releases automatically.
The electric brake has a **** feature programmed into it. If you are driving real slow and for some reason, you open the door (say, to try and clear a tight obstacle), it will set and stop you cold. You may be able to manually disengage it then but it's a real pain feature.
I did get a fraction more lateral Gs that I never pictured. Your numbers are awesome but my braking Gs will never reach yours because I have a ton of negative camber, decreasing my braking ability. I'm good with that because I more than make up for it in corners. Those numbers for lateral Gs (1.1+G) are all greatly exaggerated, though, if compared to real measurements. They reflect occasional lateral slip from bumps and subsequent sudden grip.
If the system is separate, I am sure it would be temporarily or permanently disabled.
Ryan
Sam, can one drop tire psi to 26 psi and have a read out of that before starting
a track session ( while tires are cold start of the day) head onto the track
leaving the TPMS display on will it continue to read out actual PSI as you go?
With mpsc's I ve found once they get north of 36 Psi they start getting greasy
optimum hot #"S 32-36psi
I don't know the answer but I suspect it is not separate because when you apply the e-brake with your foot on the brake pedal, the pedal sinks noticeably.
I'm 99% certain that the electric emergency brake is a separate unit from the main service brakes. Tim has that great Technical Information book for the car. I'll bet it's shown in there....Tim?
Also, after reading about the pedal drop in Sam's car I went out, started mine up and tried releasing and setting the e-brake several times and could detect no change in the pedal position. I can't explain the discrepancy with what Sam experienced.
I've never tried the "****" feature, but one can't release the e-brake with the door open unless the service brake is depressed so the two are obviously related.
It is possible.
BTW: There is a separate fuse just for the e-brake button....
Received 1,224 Likes
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
