991 GT3 owners that had a 997.2 GT3
Good catch. Yes, the 991 TT uses the old design:
Evolution of the CL design is inevitable, later versions should be better. Doing right by their customers...if you mean introducing a new service schedule late in the 997.2 lifecycle for CL maintenance which personally cost me over 6.5k. And then making it a little bit better in the 991. Real solution is to drop CL...Think how many people here would tick the 5 lug box if it were optional versus CL when buying the car? Changing wheels would be a fraction of the time as well and believe me I've got it down to a fine art swapping wheels at the track with CL, huge torque wrench, truck brake depressor....
Serge and Mike, thanks for the info. When it says the carrier bolts are now fixed to the hub instead of the brake chamber, what does that mean? The 5 red drive pins bolt to the hub now and not to the brake hat?
About the new wheel bearing, it's better for marketing to say that it comes from the Cup.
I can't make a comparison personally, but this has a bit more specific information:
Central locking
The central locking on the new 911 GT3 is a completely new development
with higher load limits and improved suitability for track use. The new
911 GT3-specific central lock is identified by a more robust wheel hub for a
significantly improved camber stability and carrier bolts that are now fixed to
the wheel hub (997 GT3 ll: fastened to the brake chamber)....
Central locking
