Significance of Torque Vectoring?
#31
PTV is simply a tool to help overcome the disadvantage of a 40/60 weight distribution. Another solution would be to move the engine into the back seat area. But then it wouldn't be 911, would it????
#32
I don't think the PTV saves your butt like PSM, but it does have complete control over which rear wheel gets power and how much. It also can individually brake the wheels. . . . all to keep the car in a neutral attitude.
Actually I take that back somewhat. Initial reports cite that with PSM off, the GT3 is set to oversteer.
IMO, Porsche has simply adopted *old* technology here; Fiat has been doing it for some time.
At the end of the day, there's much less see-sawing of the steering wheel to keep the shiny side up. Turn and you go that direction. PTV is a major component that adds to overall agility and predictability of the new 3 according to pag's literature.
The Cayenne obviously isn't a sports car but it does handle really well. It goes where I point it, which makes it fun to drive, in part because of PTV. It doesn't feel artificial; it's just predictable and responsive. I suppose if it pushed more I'd have to compensate which would require more "involvement" but personally I don't find cars that understeer all that much fun to drive. PTV helps eliminate that, apparently in the GT3 as well, from all of the descriptions about how low speed understeer is all but gone.
As you said earlier, it's all about picking the place on the handling continuum that hits your sweet spot. Not everyone has a situation that allows for multiple sports cars so there are compromises and we all decide where to make them. There's not a right or wrong answer here; just saying that in my experience torque vectoring, if it's properly implemented, doesn't necessarily detract from the driving experience.
#33
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 4,325 Likes
My Cayenne GTS has PTV and I like the way it corners and handles on both road and track (yes, I've tracked it). But in a sports car, I like the challenge of getting the car through the corner, using techniques such as trailbraking, 'pitching' it into the corner, carrying yaw angle through the corner, lifting, and using power to get some oversteer (or neutralize understeer). PTV apparently makes these techniques largely unnecessary which, again, is good for lap times but maybe not so good for learning to drive and having fun doing it.
#34
If you don't believe that based on a description of how it works, surely you've seen the videos with CH, Suttcliffe, and others pitching GT3's with PTV, into turns, hanging out the tail, and making adjustments with the throttle. You don't need to worry that torque vectoring will ruin the fun.
#35
Manifold, you keep using the word "apparently" however there is nothing apparent about it. Torque vectoring simply doesn't work the way you think it does, and has no affect on trailbraking or the ability to do any of the other things you mention.
#36
Mike, though I've not driven a PTV car, I understand that the computer modulates L/R rear wheel tq from 0 to 100%. Fully open to fully locked and everywhere inbetween. And, it can brake wheels as necessary to maintain your intended line based on throttle position, steering position, speed, yaw sensors etc etc.
In essence, it takes a mechanical LSD and adds a brain to it and can now accomplish things in terms of balance that a mechanical unit cannot, since all mechanical units have tradeoffs. I take CH, Suttlcliffe's etc antics with a grain of salt. I doubt very much these fellas were getting her all loose b/c they had to in order to turn a fast lap. It was for show.
I still remember Clarkson's yeeeeehaaaaw when he drove the 430 with the ediff stating how it made him look like a superhero.
#37
#38
I don't doubt that CH et al were doing what they were doing for show. The point is that PTV wasn't preventing them from hanging out the tail or balancing the car with the throttle which I think was Manifold's concern.
SamFromTexas has it exactly right. PTV is a minor aid, not a cure-all or savior, and from what I understand about it, it doesn't keep you from doing what you want to do with the car.
#39
#40
PTV doesn't actively distribute power. It's simple physics. One wheel is slowed slightly by moderate braking. The other wheel is now turning slightly faster so it causes the car to want to rotate. It's effective at turn in but not elsewhere and gives the chassis a nudge, not a major adjustment. All the other things you want to do with the car won't become unnecessary.
We can talk about this till we're blue in the face. When cars start to get into the hands of owners we'll find out what's what. I get that some don't want to take the chance but I honestly think the risk of disappointment is very low. Just my $.02......
#41
Probably also worth noting that I heard last year from a 991S driver that his rear brake pads were getting used up much faster than his front pads on track, apparently because PTV was pretty busy back there. In cars without PTV, the rear pads generally last at least twice as long as the front pads.
#42
Mike, I think you have it wrong.
http://press.porsche.com/vehicles/2014/2014_GT3_USA.pdf
"The rear axle of the new 911 GT3 is equipped with Porsche Torque Vectoring Plus (PTV Plus)
as standard. The system, which was adapted specifically for the 911 GT3, consists of an
electronically controlled, fully variable locking rear differential and selective braking inter -
ven tions at the rear wheels. In combination, these features provide high traction on changing
road surfaces, an improvement of lateral dynamics, more precise cornering, and increased
driving stability"
It's essentially a smart mechanical diff. Doesn't take the fun out of trail braking, inducing some rotation midcorner with some lift, or pitching the car around. Rather, I bet money that it will *remove* the need for some portion of these inputs given the 3's ability to hold a line.
Whether it's PTV a combination of PTV + RWS, or PTV + RWS + PASM + enhanced track and wheelbase. . . I guess it doesn't really matter. You can't turn these items off so you are stuck with a more *perfect* car, like it or not! LOL.
I'm not terribly concerned as I see the issue as the natural extension of the 997 GT3.
driving stability"
#43
#44
I believe it was Stout? who said that while he has a lot of respect for the GT-R, the GT3 is not anything like it despite all the electronics.
Manifold, I wouldn't get yourself too worked up about anything in the car other than PDK based on the reviews we've gotten so far from CH Sutcliffe and Stout.
PDK aside, it's a 10/10.
So let's focus on the MT/PDK debate, shall we?
j/k
j/k
#45
I don't expect the GT3 to be much like the GT-R overall, and I'd definitely pick the GT3 between the two, but I think the GT3 has definitely moved in the GT-R's direction, and the question now is whether it's too much. I started this thread because I haven't seen PTV discussed much, and I'm fearing that its effect may be more than people realize.
