US Configurator
#91
Humm, 95ah battery (if correct and i don't see why not with rws)
something like this.... It's 26.4 Kg---- Max voltagefreaks is 45ah..currently.
Brand: Bosch
Trade name: AGM HighTec 595 901 085 95 Ah
Length : 353 mm
Width: 175 mm
Height: 190 mm
Capacity: 95 Ah
Cranking amps: 850 A
Accumulator terminal allocation: “+” on the right
Maintenance: not require
Manufacturer: Germany
Warranty / Service: 24 months
Price per: pcs
Brutto, package size: 26,4 kg
Brand: Bosch
Length : 353 mm
Width: 175 mm
Height: 190 mm
Capacity: 95 Ah
Price per: pcs
#92
#93
#94
#95
An optional lift system at the front axle raises the front end by 30 mm. Operable up to a speed of approximately 50 km/h, it minimises the risk of grounding on kerbs, ramps and car park entrances.
I guess it depends on how you interpret "front end".
#96
Porsche describes it this way:
Some more details:
"The function module is a compact unit located at the front of the centre tunnel and is approx. 80 cm long. The pneumatic compressor generates pressure of up to 20 bar if required. The pressure reservoir has a fill volume of approx. 1 litre and stores the pressure required for the system to function. The compressed air system is controlled by means of a valve block unit. The system weight of all components of the front axle lift system is approx. 7 kg."
#97
The ground clearance at the centre of the front axle is 93mm (3.66in) which is exactly the same as the 997.2 GT3 RS.
The approach angle in the front is 5.8 degrees versus 5.6 degrees for the 997.2 GT3 RS.
The ramp break over angle is 5.1 degrees versus 10.3 degrees for the 997.2 GT3 RS.
Is this compliant with your favourite coffee shop parking lot?![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
