991 GT3, GT3RS, GT2RS and 911R 2012-2019
Oil change - whats the current thinking on oil
Old 06-15-2024, 11:54 PM
JCGT3rs
JCGT3rs's Avatar
Default Oil change - whats the current thinking on oil
Hey guys ...
I've got the alert to change oil in the next few weeks and before I order, I wanted to see what the current oil selection is being recommended? Car is not tracked.
Thank you
Old 06-16-2024, 01:08 PM
Indyxc
Indyxc's Avatar
Originally Posted by JCGT3rs
Hey guys ...
Thank you
Which GT? Under warranty or not?
Old 06-16-2024, 02:00 PM
JCGT3rs
JCGT3rs's Avatar
.1 3RS and no warranty ...
Old 06-16-2024, 03:01 PM
phoneyman
phoneyman's Avatar
I have no opinion but am also looking for answers in this thread for new-to-me 3RS.
The previous owner indicated he used LiquiMoly Molygen 5/40, with MOSo2 every change, and an occasional bottle of Ceratec, from 3,140 miles til 17,120 miles, then changed to LM Toptec 5/40 for the next 2k miles until selling the car to me.
I dont know why the formula change was made or anything about the specific oils but its nice to have a starting point and the general history of my car.
LavaRS (07-24-2024)
Old 06-16-2024, 04:21 PM
Berjar
Berjar's Avatar
I used Mobil 1 0W40 4 quarts with 2.5qts (aprox) of Racing Mobil 1 0W50 to get the ZDDP to about 1400 PPM. Now with 40k miles and out of warranty I use 5 quarts Mobil 1 15W50 and 1.5 quarts 0W30 Mobil 1 Racing. Engine runs fantastic and my cams look like new.
Indyxc (06-16-2024)
Old 06-16-2024, 04:56 PM
GrantG
GrantG's Avatar
Received 5,128 Likes on 2,889 Posts
Since you’re out of warranty, you have more freedom to do as you like. Probably some good options with Motul, LiquiMoly, and Driven.
If one wanted to stick with the Porsche recommended stuff, make sure you use the new “C40 GT” stuff that is made especially for the high revving GT cars.
Old 06-16-2024, 05:00 PM
Indyxc
Indyxc's Avatar
If you want to protect the cams, run a 5w50 oil. HTHS (High temp shear strength) is much higher, especially when the oil is used up. Also, the new Mobil 1 Supercar 5w50 made for the Corvette z06 finger followers with DLC wear proteciton has nominal 1200 ppm of ZDDP higher moly, lower detergents and base forumulation is very similiar to Mobil 1 ESP X3.
To the original question for a .1 GT3 RS.
If approvals are important to you and you're in CA, then either Mobil 1 FS X2 5w50 or Motul Xcess Gen 2 5w40. I would not run Mobil 1 0w40. It shears down quickly to a 0w30 leading to increased wear.
If approvals are not important to you, Mobil 1 Supercar5w50, Driven DT40 or DI40, Motul 300V 5W40.
.1 GT3 RS here, and I have Mobil 1 5w50 Supercar ready to go in next oil change.
74goldtarga (06-17-2024)
Old 06-16-2024, 07:36 PM
JCGT3rs
JCGT3rs's Avatar
thank you guys .. very helpful... much appreciated
Old 07-19-2024, 06:38 AM
F1 Kevin M
F1 Kevin M's Avatar
I’m about to do my first oil change on a 991.2.
Looks like Motul 5w40 8100 xcess seems to be a common recommendation, going to try that. I’m in CT and don’t really drive the car below 40F
EDIT: Also seems Liqui Moly Leichtlauf 5W-40 is also a common recommendation
konrad h1 (07-19-2024)
Old 07-19-2024, 05:09 PM
Wasserott
Wasserott's Avatar
Amsoil for my fleet!
Old 07-19-2024, 05:11 PM
GrantG
GrantG's Avatar
If my warranty was expired, I would also take a look at Motul 300V Racing oil
Old 07-19-2024, 08:41 PM
bmw_e30
bmw_e30's Avatar
i use redline 5w-50 or you could use 5-40 as well
https://www.redlineoil.com/high-performance-motor-oil
ztnedman1 (07-19-2024)
Old 07-24-2024, 01:01 AM
M3the01
M3the01's Avatar
Motul xcess is good when in warranty as it's approved but switch out to the Motul Sport 5w50 as it's an ester base and going to have much better sheer strength.
Old 07-24-2024, 08:13 AM
parkerfe
parkerfe's Avatar
Using a different brand oil will not void your warranty in the USA, as long as the oil complies with the Porsche spec.
Old 07-24-2024, 11:51 PM
LavaRS
Cruisin'
LavaRS's Avatar
Mine is a .1 and out of warranty. Thinking about going this route...
https://www.motul.com/ae/en-US/produ...petition-5w-40
or
https://www.motul.com/ae/en-US/produ...petition-5w-50
Quick Reply: Oil change - whats the current thinking on oil
