speedshifter for my GT3...
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/pxl_20230812_191901584_8a27837e3d25e8437777ada6a5affeb00bfb6cf0.jpg)
voodoo blue, R in speed yellow!
![](https://cimg2.ibsrv.net/gimg/rennlist.com-vbulletin/1500x2000/pxl_20230813_224115806_action_pan_01_cover_131ded97f6629f2f3769f5444a99a458fa1d2f1b.jpg)
https://sportshifters.com/ its their "GT3" model, with custom colors (voodoo blue and speed yellow), Roy there is a joy to work with! - only around 150eu ....
its a breeze I did this yesterday in about 10mins, all you need is a small trim tool to pop the boot off at the front checkout
for boot and **** removal instructions!
I cant think why I'd spend $$$ on an OEM shifter like that from the R with a product like this ... its almost too nice to install!
doh! - fixed it for you!
https://sportshifters.com/collection...tom-shift-****
you can email Roy at: mailto:info@sportshifters.com
then you turn the ring at the base of the **** on the underside of the boot anti-clockwise for around 45 degrees until it clicks
then you pull up on the **** ... pop off comes the **** and boot together...
there are 4x little retaining clips on the base of the **** that retains it to the boot ... squeeze those and gently pull to
remove the **** from the boot ... with a little care out comes the ****!
voila you are ready to install the sport shifter ****!
reading the above this sounds a little like something from https://en.wikipedia.org/wiki/Viz_(comics)
now enjoy you new shifter! (not ****) snurk snurk...
