Reduced engine power can drive on
2014 991.1 original engine, no tracking. 15k miles Car in for oil change brake flush one month ago everything ok. Parked until today started up got the reduced power can still drive message when pulling out of garage. Turned off restarted no error message….concerns?
No codes found
Time for an Italian tune up
Had that yesterday tracking the car in Spa as well.
Going from full throttle to 60mph max. from one second to another.
After I parked the car and let it cool down for 15 minutes, everything was fine. Any ideas?
Originally Posted by Karthoum
Will do and report back in here ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Curious to see if the Icarsoft ODB reader will be able to read any error codes as well.
Parked for a month with or without battery maintainer? Low voltage does funny things on these cars. I've had the same issue once on my 991.1GT3.
Next time it happens, pull the codes before shutting the car off if possible.
Had the same thing happen to me a few weeks ago and it was the accelerator position sensor that had gone bad. Thankfully it was only giving erroneous readings at the higher end of the pedal travel so driving the car on the street and highway was unaffected.
