Jacking a GT3RS with normal Jack Stands
This Jack Point Stand and these Esco Stands?
What is the process / sequence?
On the end w/ the Esco stands, how is that end lifted?
2. Lift other side of car from the rear jacking point with Jackpoint top plate (will lift entire side of car), place standard jack stand under front jacking point (can use a jack pad that fits into receiver hole if you like) and and lower jack to rest on Jackpoint stand under rear jacking point.
If you are using the Jackpoint stands with the Essco stands make sure you get the correct Esscos. The JackPoints are 12" high so you need to get the Esscos that have a minimum height of 11" . I initially bought a set of stands from Harbor Freight but they were too tall.
