Oil change question
Hi for the 991.1 GT3 there is a bolt at the rear of the pan and a bolt on the right side towards the front by the sump tank. Could I remove the rear bolt and drain instead of the side bolt.
Thanks in advance.
Thanks in advance.
I believe it’s recommended to remove three plugs in order to drain max oil out.
