991 GT3, GT3RS, GT2RS and 911R 2012-2019
27,000 mile 4 year service GT3T
Old 02-25-2023, 05:56 PM
Berjar
Berjar's Avatar
Default 27,000 mile 4 year service GT3T
Thought this may be of interest. Just had my 4 year 27,000 mile service/inspection. Car alway driven at leat 20 minutes so no short trips. No track but always driven hard.
-50/50 mix of 0w40 and 0w50 Mobile one racing oil.
-Oil changed at 500 miles, 1,500 miles and then every 4,000 or so miles.
-Lucas UCL used in fuel at every fill up
-Always used non-ethanol premium.
Issues:
-leaking clutch master cylinder fluid line
-Shock on engine cover weak
-Valves are probably in need engine out dry ice de-carbon cleaning.
Other than that car is great. Cams look new.
Old 02-25-2023, 06:19 PM
74goldtarga
74goldtarga's Avatar
So the pictures show gunk on the valves? Is this a common problem? I haven't heard of that before.
Old 02-25-2023, 06:39 PM
Berjar
Berjar's Avatar
Yes it is common to all direct fuel injection engines.
Old 02-26-2023, 07:53 AM
177mph
177mph's Avatar
What is a GT3T?
Old 02-26-2023, 11:07 AM
Jbravo23
Jbravo23's Avatar
Received 1,790 Likes on 725 Posts
Sup with the Lucas UCL? Any benefits? Haven’t heard people adding to these motors.
Old 02-26-2023, 11:53 AM
RudyP
RudyP's Avatar
Received 1,593 Likes on 569 Posts
Originally Posted by 177mph
What is a GT3T?
GT3 Touring
Old 02-26-2023, 02:16 PM
Angryinch
Angryinch's Avatar
Received 1,176 Likes on 691 Posts
You should have the intakes walnut blasted if they are collecting carbon.
This is why meth injection is great, it helps to keep the intake valves nice and clean. (More so used in turbo cars)
Old 02-26-2023, 02:25 PM
Berjar
Berjar's Avatar
I was wondering if Meth injection would be a good idea?
We are going to use Dry Ice blasting to clean them. Unfortunately the moto needs to come out to do it.
Lucas is a fuel additive that lubricates the pump, injectors and cylinders. I use it in all my cars.
Amazon Amazon
Old 02-26-2023, 02:29 PM
Angryinch
Angryinch's Avatar
Damn! Engine removal for that, eeek. I guess with the flat 6 style there is likely no access..
I would for sure install a water/meth system on the car, just to keep the intake valves clean. It will help with IATs too if you live in a hot climate.
Maybe talk to M Engineering, see what they say. I have the same kit for my TTS.
Old 02-26-2023, 03:51 PM
Berjar
Berjar's Avatar
Thank you fpr the tip. I will definitely be looking into it.
Old 02-28-2023, 01:06 PM
JCviggen
JCviggen's Avatar
Received 1,584 Likes on 610 Posts
That is a rather minor amount of crap on the valves, unproblematic. If you blast it off it will be back before long, pointless exercise. There is no significant performance deg from carbon buildup with these engines...
Old 03-01-2023, 07:11 AM
markiegt3
markiegt3's Avatar
Interesting. The audi v8 suffers a significant power drop due to dirt/carbon buildup. Why doesn't the Gt3 engine? Longer valve stems, so flow isn't restricted?
Old 03-01-2023, 07:48 AM
JCviggen
JCviggen's Avatar
Because the crap buildup on the old Audi FSIs is a lot worse than this (modern DFI engines have implemented some mitigations to stop it becoming excessive)
Ex B7 RS4 owner here
zmon (03-01-2023)
snikwad
snikwad's Avatar
i was thinking the same thing. That really doesnt look like much, i wouldnt worry about it yet.
Old 03-01-2023, 10:40 AM
markiegt3
markiegt3's Avatar
Good to know!
Quick Reply: 27,000 mile 4 year service GT3T
