Lap time improvements would likely be track dependent, but with that little increase in downforce I suspect any gains would be minimal.
I question the curves Versus published - - why is the baseline curve a line but the riser is a shaded area?
I don't have any insider info nor do I vouch for Verus, but I believe the shaded area is because the Verus wing has 3 AoAs (angles of attack) so the least aggressive setting is the bottom of the shaded area, the most aggressive setting is the top of the shaded area, and the middle setting is somewhere in between
Thanks for providing that detail.
Still doesn't seem to be a big enough performance jump, although I realize the OE wing is also a limiting factor.
Is the baseline the standard wing? Shouldn't that also be shaded, as adjustable too?
So I finally installed mine, had to wait for revision 2, v1 didn’t fit.
only done 2 hot laps with them on. Only data I have so far is on the main straight, top speed in 26*C was 241, and with those on with a temp of 38*C top speed was 238kph.
plus finally being able to see behind you on the road is a plus.
Was that with the wing at stock angle or a different angle?
