CHANGE YOUR DIFF OIL
#32
PDK Clutch vs. PDK Trans Service?
Can anyone help me understand the difference between the PDK clutch, PDK transmission, and a differential fluid service?
I believe the PDK clutch service is not as complex and does not require the special tool?
Had a PDK clutch service performed, and 7 liters of part# 000-043-305-14 were charged/listed on invoice, and does the PDK clutch fluid really take 7 liters?
Appreciate any clarification and feedback.
#35
how many events?,
I had been on my GT3RS already on 10 DE and over 2,200 miles, always change motor oil/filter and brake fluid every 3-4 events, tires every 5 events.
Considering changing Differential oil?, should also change the PDK fluid?
#38
#39
I’m about to tackle this on a 991.2 GT3. The workshop manual shows a solid plug where the diff / transmission fluid fill hole should be, but instead there’s a banjo bolt as noted in the photo above. Can someone who has completed this service verify that this is the correct fill hole? I’ve searched a ton of posts but haven’t been able to find a photo to confirm. Thanks!
#40
I do a PDK drain and refill (3 quarts of Pentosin, no pan removal or anything) plus a rear differential drain and refill (3 quarts of liqui moly 75w90) every other oil change. I order everything through FCP Euro, since they have the lifetime warranty on the fluids. Yes there is shipping back and yes they increase their prices ever so lightly vs. time but I dig it. Oil changes roughly every 2K-3K miles. I do this myself in my garage as I find it therapeutic - this is not for everyone but works for me and my old 52K mile 991.1 GT3 with G6.
Indyxc (03-14-2024)
#41
#42
That is the correct hole for the diff.
I used Millers XF Premium MTF 75w-90 as it has a direct PN equivalency on the product sheet and it is a premium oil. OEM oil is available only in 20l drum.
#44
Awesome - thank you! I was able to get the OEM Mobil 1 Mobilube PTX 75W-90 fluid through Suncoast Parts - packaged in 1L containers.
https://www.suncoastparts.com/produc...l?gad_source=1
