Eventuri Carbon Fiber Intake
Bumped this back up, not many experiences post with GT3 RS on here. Thinking it might be my next mod after Dundon Street Headers.
Thoughts and experiences?
this set up does not change the throttle body, which Dundon says is the main source of restriction on the air flow. no one will see the carbon so I would go with the Dundon set up - this is my plan at some point.
There is this throttle body, increases the side from 82MM to 86MM. I think this throttle body + Eventuri intake while probably not as good as the Dundon, is a cost effective option.
I am also interested in more intake noise. I like intake noise more than exhaust noise (Will be running Dundon Long Tube Catted headers + stock muffler with JCR TI tips).
tgibrit (06-21-2024)
If you only want to spend ~$2500 and also don't want to tune, the Eventuri is the only option that I've seen and makes sense to me. You're going in with the right level of expectations.
Indyxc (06-22-2024)
